No it doesn't matter. The LED should have the same voltage drop.
But don't change the color.
About the heatsink, I usually use a Multi, 2U 19" enclosure, available from Powerbox. www.powerbox.se
Which have heatsinks on the sides, the biggest enclosure have a thermal rating of 0,17K/W.
/Freddie
/Freddie
Thanks for the responses. In the assembly instructions Rod states that C1 can be anything from 1 mf to 10 mf. I have two caps in hand which fit the bill. One is a 4.7 mf electrolytic, the other a 1 mf metal film box cap.
Question: Is there anything to recommend one over the other or does it (as the instructions appear to suggest) really not matter as long as it is between 1 and 10 mf?
Thanks again
Steve
Thanks again
Steve
