You may be interested in this:
http://www.diyaudio.com/forums/twisted-pear/231514-asynchronous-usb-audio-class-2-module.html
Brian,
are there any specifications for the eval board? Like THD? THD+N?
/S
/S
Yup, they are available...
OK
I do have the rev A version fo the datasheet but not for the latest ESS 9102 rev C.
I wish that ESS would publish measurement results for Fs > 44k1. My datasheet only presents results for Fs = 44k1...
/S
/S
The Eval board is what is used for the datasheet. So if you have the datasheet you have numbers.
Hi!
Just another hopeful request for the TPA ADC module with RIAA! It would be amazing to digitise the output immediately after the turntable (to minimise hum, interference and transmission losses) for input into a DAC with digital volume attenuation for real-time playback.
I know people will just ask why I don't digitise my vinyl with current ADCs for convenience... But I still want to play my records and also hear the changes with changes in my phono playback system. I think this would be the best modern solution to age old vinyl playback problems. The fidelity would probably also be even better than with traditional phono preamps and step-up transformers.
Anyway... I know you guys are super busy, but this is just a reminder that people are still watching this space!
Thanks!
Taz.
Thanks!
Taz.
Actually, people would ask, why you don't listen to your vinyl without digitizing. DACs just don't sound analog, not even the ladder PCM1704K with the digital source slaved to the DAC's clock.
Also, step-up transformers come before the RIAA equalization step and no active amplifier can beat the sound quality of a good and properly matched pair of step-up transformers.
- More Vendors...
- Twisted Pear
- ES9102 ADC Module
