Hi all
The GB is going on the right way, but we perform do better.
Glad to see that Jean-Paul has posted some good informations
My V2.6 ES9023 is now improved with 2 BlackGates in C10b & C32 positions.
Result : deeper bass (yes it's possible) and more global definition in the soundstage !!!
The output level gave a strong & clear signal, my pre is now on -30dB.
This board is a real bargain, can't wait to build a BAL version using V3 PCB.
Phil
Phil
Got the parts today!PS : Hope you'll be delivered soon.
Hi Ryssen and All
Ryssen
Glad to see you've finally been delivered
Enjoy your built, take your time, read the Build Guide too.
BTW read the EU Parts GB there are some hints about parts.
BG went from a friend old stock, he picked up two units for me.
grufti
BlackGates : NX HiQ 47uF/6.3v at C10b + 0.47uF/50v at C32
They seems to be available here : http://www.partsconnexion.com/capacitor_ele_blkgate.html
atharva
TP TOSLink module needs to be fed by SPDIF Data stream & requires min 5v external PSU as it has a 3.3v onboard reg. It's just a media converter Cu to Optical Fiber.
No input-output "matching" needed, just connect SPDIF from ES9023 to TOSLink.
Ryssen
grufti
atharva
They seems to be available here/QUOTE]
I asked them and they are out of stock,
They recomend the ELNA Slimic or serafine as an alternative.
But I cannot find any WM8804..Glad to see you've finally been delivered
Åke, check carefully inside the bag. I "lost" a few parts inside the bag, because they were stuck to the tape. Once unpacked, I "lost" at least one on the circuit board where it glued itself to the flux, but in the wrong place. Fortunately in my case none were ever really missing.
Now I searched everywhere,and there isn´t any..Åke, check carefully inside the bag. I "lost" a few parts inside the bag, because they were stuck to the tape. Once unpacked, I "lost" at least one on the circuit board where it glued itself to the flux, but in the wrong place. Fortunately in my case none were ever really missing.
Hello !
About WM8804, I've bought these :
eBay | WM8804 S/PDIF Digital Interface Transceiver 1pc.
R.C.
R.C.
All kits have been checked twice before sending, but I could have made a mistake. PM me for details and solution.
Phil
- Group Buys
- ES9023 / WM8804 S/PDIF "Subbu DAC V3" GB Interest
