I just did a little rectifier rolling....Telefunken rgn1064/2004/2504 mesh vs. non mesh. The Mesh add a 3D, a micro-resolution and micro dynamic which makes the sound-stage real.
Which amplifier are you using them in and what are the associated power tubes?
Pass DIY Addict
Joined 2000
Good morning Eric,
i used both versions of the EML300B with much pleasure.
Both have their own musical signature but that does not mean one version is better than the other; it's just different.
Currently i don't use them anymore as i traded the big amplifier for a big turntable. As a power amplifier i use my 35TG amplifier; same circuit/schematic but simply a lot smaller and less powerfull (more in line with my 99 dB speakers).
But i know the current owner of my former TB3/1000 amp still uses and likes both EML's. Still going strong.
Regards, Reinout
(included 2 pictures of the turntable which was the return in the amplifier-turntable swap: a 400 kgs air bearing instrument with pneumatic levelling devices/dampers)
Regards, Reinout
Pass DIY Addict
Joined 2000
