You would get more effects from swapping output transformers. Also, you may want to check out these links before buying more tubes.Anyone use the EML 300b mesh plate tubes in their Tubelab SE.
Is this even recommended?
Currently using Goldlion 300b's. They sound very good but would like to try some other tubes. Any other suggestion?
Debra
http://www.diyaudio.com/forums/tubes-valves/172692-sound-6sn7-3.html
300B listening tests
