I am building a Dac with Febbe's NonozII, with 2.2K I/V resistor and 1.2K Vref at 8V. It did sound great. For further improvement,
can anyone advise how to install Elso Clock KC-7 ? Can it co-existance with the reclocking device with 74VHC74 as shown in Nonoz I. Thanks for your help in advance.
Ben
Ben
Hi
If either of you two know about clock design could you check out my thread, cheers
Click for link
Click for link
Hi Ben,bsyyu said:I am building a Dac with Febbe's NonozII, with 2.2K I/V resistor and 1.2K Vref at 8V. It did sound great. For further improvement,
Ben
The KWAK-CLOCK is intended for installation in a CD-player as a replacement of the masterclock.
The Asynchronous Reclocker has its own clock with a a 100 MHz crystal and is intended for installation in a separate DAC-component.
As Stefano points out the ASR will also work with the KWAK-CLOCK-7 as a clock source.
In my experience the ASR works better with a higher clockfrequency. In due time I will try the 125 MHz Vite-on-line crystaloscillator.
If you want the schematic of the ASR just email me.
