I use the stock tubesNice, are you using the stock 6AQ5 or 6V6's?
I've had the top off of my TU-8150. I pulled the op-amp and did some listening and, honestly, I couldn't tell the difference between op-amp in and out. So now I put the op-amp back in and switched the jumper to from Ultralinear to Triode. I'll spend the evening listening that way. I wonder if I'll have a preference.
From Lowell:
Just wanted to say how pleased I am with the Elekit TU-8150! It was so fun to build and customize. But the real treat is that lush, lifelike sound… a big improvement in tone and drive over the TU-H80 I was using. Thanks so much and hope to do business with you again in the future.
https://flic.kr/p/2oEqSyW
