Excellent point!!
That gave me a good place to start. I suppose it's not just a little parasitic capacitance or leakage inductance that causes such an oscillation. So I tried disconnecting the negative feedback. The first thing I noticed was the lower output without the NFB. That didn’t seem right. It looked like I may have reversed the phase of the output transformer (?) (I had the blue and blue/yellow wires in the primary of the Hammond 1608 connected to the top tube in the schematics, and the black wire in the secondary connected to ground.)
Reconnecting the amp to the B&W 804 and the oscillation is gone. I tried reconnecting the NFB, but I couldn’t get the oscillation back again to confirm that it indeed was the problem. I suppose things got changed just enough with me moving things around that the amp is now stable even with the positive feedback (?)
I tried reversing the feedback connection with the green wires on the secondary connected to ground. I got a slightly lower output as expected. But the amp runs fine without the feedback. I’m leaving it out for now.
Another issue I had was the fuses. The HT switch helps, but still not enough. I now use a few 33ohms in parallel to limit the current on power up and use another switch to short out the resistors after a minute. I’m going to order a CL08 inrush current limiter. Hopefully that’ll keep the fuses from blowing.
All in all, things well pretty well for my first attempt at DIY. I’m now thinking about building the other channel. I’ve put a few pictures of the amp on the following website. I’d appreciate any comments on the layout, components, etc.
http://cheunglai.smugmug.com/gallery/1336901
Toroid transformer
ctaudio - if that's your first DIY amp, colour me impressed! Obviously this isn't your first circuit on a perf board though. Yeah, I was going to suggest a thermistor, but you've beat me to the punch...
Anyway, I was wondering about toroidial output transfomers, which I found on eBay (oh oh). I can get a really good price on some 10W 40% UL toroidials, but I hear they (toroid output trafos in general) have a problem when there's a DC current imbalance between the two tubes. Do we have any opinions on this? I don't have any idea how to tune current output of the tubes - is an imbalance caused by mismatched tubes, or mismatched resistors, or other parts? Can it be fixed with a pot somewhere? Careful parts selection? Could I simply put a DC blocking cap between the EL84 and the trafo, or is this a no-no? Should I just go away and read about circuits for a long time and figure it out for myself?
Jeremy
Jeremy
Thank you, Jeremy. This is indeed my first tube amp (my first analog anything, for that matter). But you are right. I have done a good number of digital boards in the past.
I've been listening to the Baby Huey (in mono) in the past hour or so. I must say I am very impressed. I can't wait to complete the other channel. I may have to retire my ML...
I've also heard good things about toroidial output transformers. I'd be interested in hearing what you find out.
This amp design uses a bias servo circuit to maintain dc balance for the toroidal output transformer.
http://www.normankoren.com/Audio/TENA.html
The two bias circuit at the cathodes of the EL84 are providing a constant and equal current draw. The absence of DC in the OPT will help to produce the excellent effects on the bass response Gingertube is talking about!
Another option, simple to implement, is the use of an LM317 or LM337. John Broskie shows it here;
http://www.glass-ware.com/tubecircuits/Tube_Auto_Biasing.html
Personally I got the impression that mox resistors don't help the sound. A little lifeless and cold. In my amp I had them in the cathode circuit only..and I prefered Dale RS-5 I tried subsequently.I’d appreciate any comments on the layout, components, etc.
I think EL84 is a very good tube/valves with many good qualities, cheap, excellent sounding and easier to drive hence design. There are many types available out there to experiment as well.
Those who are interested in high powered amplifier should look at making a total of 8 tubes(in 4 per side in PP mode) per channel giving a total of about 35watts per channel, close to class A mode.
This I think is a good project for those who are keen. I am thinking of making one.
ttan98 said:Those who are interested in high powered amplifier should look at making a total of 8 tubes(in 4 per side in PP mode) per channel giving a total of about 35watts per channel, close to class A mode.
[/B]
Hey I happen to have 8 EL84 do you know where i can find this design? Is there one that only uses 4 tubes per channel. I would be happy with 15W per channel.
ttan98 said:a total of 8 tubes(in 4 per side in PP mode) per channel giving a total of about 35watts per channel, close to class A mode.
Probably closer to 15W in Class A.
dave
2- EL84 tubes in PP operating in Pure Class A(operate at max limit) is about 12W(+/-1W), 4 tubes will give about 24 Watts, so design conservatively it will operate at 20W in pure Class A.
If you want more power, bias it in class AB mode it will give more about 35W easily or one bias the tube to suit one's liking.
One can get cheap and good quality russian EL84 or 6P14P-EV(military version) at about AUD$2-3 per tube. I just bought 4 Russian tubes (matched quad pairs for US$12.50) from Ebay.
I have not decided yet so don't put our hopes too high. I have experience in building and designing valve amp. Alternatively I am thinking of building a Nelson Pass Class A single ended, giving out 30-40 watts per side. I have all the info and parts are easily obtainable and able to get the PCB easily.... the circuit is simple to follow and soldered. The difficult is the heat generated by the mosfets, the heat sink is huge.
I can't help but think you may be further ahead running one pair of 6L6GC conservatively. Heater power (for a pair) is less than a quad of 6BQ5. With 360V plate in AB1 you'll get about 18W (out of RC-27). I'm sure 7591A's will perform similarly.
I'd stick with the 12~14 watt rating for a pair or move up to a more suitable tube for higher power.
-Chris
-Chris
anatech said:I can't help but think you may be further ahead running one pair of 6L6GC conservatively. Heater power (for a pair) is less than a quad of 6BQ5. With 360V plate in AB1 you'll get about 18W (out of RC-27). I'm sure 7591A's will perform similarly.
-Chris
Yes, but you will need three times the grid drive
Yves.
ttan98 said:2- EL84 tubes in PP operating in Pure Class A(operate at max limit) is about 12W(+/-1W), 4 tubes will give about 24 Watts, so design conservatively it will operate at 20W in pure Class A.... Alternatively I am thinking of building a Nelson Pass Class A single ended, giving out 30-40 watts per side. I have all the info and parts are easily obtainable and able to get the PCB easily.... the circuit is simple to follow and soldered. The difficult is the heat generated by the mosfets, the heat sink is huge.
between these 2 which is preferred? 20W EL84 v/s 30-40W SS (NP)?
navin said:20W EL84 v/s 30-40W SS (NP)?
Don't know about that, but i prefer our 4W EL84 (triode class a) vrs the 15W miniA, At least on the speakers we typically use. One thing we found very interesting in one session was that the tube amp had better bass.
dave
Hi Dave,
-Chris
Is it possible that may be a damping factor issue?One thing we found very interesting in one session was that the tube amp had better bass.
-Chris
I have not owned a single ended amp before it would be interesting to build one and compare it with a push pull valve with the same power output.
There will be some differences in sound quality between the 2 amp. and each has its own characteristics besides the influence of components and contruction of the amp. I still cannot pin point the diff. characteristics(*) as yet as I have not owned or listened to one for a lengthy period of time. That is the reason I like to build one. I don't think one amp better than the another it depends on individual taste and mood at the time of listening.
(*)Characteristics I mean for example, pentode vs triode in push pull topology. Those who have compared between these 2 modes will know what I mean.
anatech said:Is it possible that may be a damping factor issue?
possibly... but i expect the SS amp would have higher damping factor (althou neither of them is going to be what would be considered high)
dave
- Tubes / Valves
- EL84 Amp - Baby Huey
