adamus said:Just checking, i do want the 18ohm side to ground, and the 5k6 side to cathode?
YES.
If the CCSs apear to be working correctly, the question is what is loading your PS down to 230V (assuming the PT is dimensioned to carry the intended load). Should be about time to check with tubes fitted in only one channel.
SveinB.
the tube red plate very quickly.
Something is seriously wrong. but cant for the life of me work out what.
here is a pic if that helps
checking through each channel with schematics i see no errors.
I am using 6p14p, which have been said to be a direct substitue with the EL84. They glow red quicky, by which time i shut down.
If the plates are glowing, that suggests to me that the bias blocks arent working, however, checking witha 9v battery shows they give 34ma exactly - so what else could cause the red plates?
adamus said:checking through each channel with schematics i see no errors.
The bias blocks have the 16ohm side going to 0v, and the 5k6 side to the cathode.
It's possible that the 9v battery itself is unable to give more current.
Does the 9v drop when you do this test ?
All symptoms indicate that the bias block are faultly.
What happens if you (temporary) replace each with a 150 to 300 Ohms resistor ?
Yves.
Thanks for the help guys, all sorted. It was indeed the bias block.
I was using a datasheet for a different mje340, apparantly they do differ per manufacturer.
B+ is now 335v, ccs is giving 34ma. quick mental calc and that gives 11.5 watts dissipation per valve.
Its high but ok?
again, thanks for the advice
Its high but ok?
Nice to know it worked out OK - without any black smoke and component damage.
Since you still have the cover off, could you measure the cathode voltage? I am a bit curious how much voltage the CCS takes up.
I think I would have preferred a small negative supply for this, but maybe Ian/Gingertube would like to comment on that.
Do you have any other measuring gear available (apart from the multimeter)?
SveinB.
SveinB.
no i dont, but give me a month and i will have an Oscope.
I have retired for the night, but will get the voltages for you tomorrow. I assume you want cathode to ground?
I'll go through final adjustments tomorrow, get the base plate on.
By the way, the 6p14p tubes glow blue inside (as others have experienced). Bit alarming at first!
It made some music, but oddly, i couldnt turn the volume all the way down......?
Svein_B said:Nice to know it worked out OK - without any black smoke and component damage.
The CCS takes up exactly the voltage needed to bias each tube for it passes the expected current.
That's CCS job
Must add than I personnally do prefer fixed grid bias and no cathode bypass caps.
My faith
Yves.
a rather unglamourous shot, without knob or the baseplate screwed on.
Yvesm said:The CCS takes up exactly the voltage needed to bias each tube for it passes the expected current.
That's CCS job
Yes, of course.
I was for a moment there concerned that the CCS would require some volts to do its job and thus reduce the available g-k voltage swing. It is however not relevant here since the CCS only defines the DC current and is bypassed for AC.
SveinB.
a couple of questions...
My B+ is 340v, outputs are running at 34ma, so the power dissipation is roughly (340 – 8ish)*(0.034) = 11.3 watts, which is close to the upper limit of the 6p14p. Is this too high, or shall I risk it and just assume tube life will be reduced? The 6p14p is meant to handle slightly more power than the el84
Somewhere in the thread it was suggested that the 33ohm resistor between screen grid and UL tap should be increased if using a high B+. I only have a 33ohm 2w kiwame in there at the moment. Should I increase this to say 250ohms given my high(ish) B+.
There is a strong blue glow on the inner side of the anodes – Its certainly blue and not the dreaded purple/pink. Is this normal?
I haven’t spent any time listening yet, so I’ll report back after the ‘new toy’ effect has gone.
adamus said:a rather unglamourous shot, without knob or the baseplate screwed on.
Nice housing! Is it your own doing?
And is that Hammond iron?
hmm, problem number 2,
i cant equalise the anode voltages of the 12ax7, the trimpot seems to have no effect.
The css is the same as the schematic, ecept i removed the opt cap and resistor, replacing the resistor with a short and eliminating the cap.
any ideas? Help much appreicated.
adamus said:tested the css out of circuit, it works. any other reason why I cant balance anode voltages? They are within 5%, but i expect that isnt good enough.
Mmmmh ...
100 Ohms trimpot cannot have large effect !
Anyway, less than 10% anode voltage inbalance is really ... peanuts.
This phase splitter is as well balanced that the plate resistors are.
Don't bother about small DC differences due to tube tolerances, this has NO effect on AC balance cos the CCS in the cathodes forces the sum of anode current to be constant, thus any current change in one triode produces an absolutly equal change in the other one.
So, if plate load resistors are equal, voltage swings are.
Yves.
- Tubes / Valves
- EL84 Amp - Baby Huey
