EL504 model
Try this one.
* R McLean 7 February 2006
* EL504 pentode
* parameter extraction, from data sheets, 7 February 2006
* grid current not modeled
.SUBCKT EL504 A S G K
+ PARAMS: Ex=1.36356218017116 Kg1=309.008226941514 Kp=24.0913886609314 Kvb=9.84050855226085 Mu=7.9025411899847
+ Exd=1.01472919685363 Kd=92.2849763943327 Ks=0.270652934579086 Kg=0.00189539610643784
+ CCG=22.0P CPG1=1.75P CCP=9.0P
Eat at 0 Value={limit(0.636*ATAN(limit(V(A,K),0,2000)/KVB),0,1)} ; arctangent shaping
Eme me 0 VALUE={PWR(LIMIT(V(A,K),0,2000),EXD)/KD} ; diode line
Egs gs 0 VALUE= {V(S,K)/KP*LOG(1+EXP((1/MU+V(G,K)/V(S,K))*KP))} ; effective voltage
Egs2 gs2 0 VALUE={(PWR(V(gs),EX)+PWRS(V(gs),EX))/(KG1*0.636)} ; total space current
G1 A K VALUE={LIMIT(V(gs2)*V(at),0,V(me))} ; plate current
Escrn sc 0 VALUE={KS*V(gs2)*(1.1-V(at))} ; reverse arctan shaping for screen current
G2 S K VALUE={Limit(V(sc),0,10)*LIMIT(V(S,K),0,10)/10} ; screen current
* no grid current data available so comment out the grid current line
*G3 G K VALUE={PWR(LIMIT(V(G,K)+1,0,1E6),1.5)*(1.25-V(at))*KG} ; grid current
C1 G K {CCG} ; CATHODE-GRID 1
C2 A G {CPG1} ; GRID 1-PLATE
C3 A K {CCP} ; CATHODE-PLATE
.ENDS EL504
Try this one.
* EL504 pentode
.ENDS EL504
EL509 model
here is a EL509 model you can try
* R McLean 11 February 2006
* EL509 pentode
* parameter extraction, from data sheets, 10 February 2006
.SUBCKT EL509 A S G K
+ PARAMS: Ex=1.30254251632683 Kg1=95.6295743252665 Kp=9.99615840510116 Kvb=37.9209077642428 Mu=10.3695759657906
+ Exd=1.01930710584093 Kd=52.271082959232 Ks=0.221606928008962 Kg=0.00189539610643784
+ CCG=37.0P CPG1=2.5P CCP=18.5P
.ENDS EL509
* EL509 pentode
.ENDS EL509
lorylaci said:Hi!
I'm looking for SPICE models of PL504 and PL509 to use with NI Multisim. I tried to use these models in NI Multisim, but did not work. Does Multisim's SPICE language different?
You should be able to use modes above, but first you have to build a new pentode schematic model with pins named according to .subcircuit model of pentode used. Spice model for PLxyz/ELxyz is the same, as no heater voltage/current is spiced.
- Tubes / Valves
- EL504/PL504 spice model
