Wattage 5W
Max. Current 100mA
Primary (input) Impedance 15K Ohms
Screen/Grid Tap 40%
Secondary (output) Impedance Depends on model.
Frequency Response 40~18K Hz., <1dBu
THD+Noise <0.1% @ 1K Hz.
Bobbin Material Nylon 6/6 GF-30
Flamability Rating Class B 130°C
Core Material M-6 29 ga. grain oriented lamination steel
Secondary Insulation (transformer) Clear air dry polyester varnish
Termination 0.187" (3/16") quick disconnects
Mounting Zinc plated steel channel/frame
Weight 1.2 lbs.
Compliance RoHS & REACH
Yes I read it but my ignorance don't let me see or understand.
Max. Current 100mA
Screen/Grid Tap 40%
Weight 1.2 lbs.
In technical English the word "screen" may mean:
1. an electrostatic screen - for example, as included in some power transformers - this should be grounded
2. an abbreviation of 'screen grid' - for example, as included as a tap in UL output transformers - this should be connected to the screen grid (for UL) or left isolated (for pentode or triode operation).
@merlin - please do not start multiple threads on the same topic. Your threads have been merged.
Sorry about my comments above, but you can do what the rest of us do when we read in a foreign language, use Google Translate:
Screen/Grid Tap 40% = Pantalla / Grilla Tap 40%
OTOH, if you don't know what the screen tap is for, then it's a different matter...
- Tubes / Valves
- Edcor GXSE5-600-15K for 300B HPA
