Eclipse CD101-II CD Player - which Samsung Standart Model ?
Eclipse CD101 CD Player - Schematic wanted
This Eclipse CD101 CD Player you will find currently about the ebay
Item number: 170747645514 and Item number: 270909123275.
The internal Samsung based PCB (type AR-004, SSP94V0) is equipped with follow VLSI circuits from Samsung:
KDAO318LN (KDA0318LN, DAC)
KS56C820-69A (MCU, LCD Display-Driver)
KS9211B (PCM decoder + Error correction)
KA8309B (servo-processor)
KA9201 (RF-Summing-Amp)
The loader and mechanism is the same as used in the models "CD-4", "CD-6" and CDT (CD4, CD6, Discmagic) from Cambridge Audio (Sanyo-based). The optical pick up is Sanyo's SF-91 (SF91). The kind of manufacturing is also the same as by the mentioned Cambridge models, launched arround 1996-1997 (e. g. case finish/paintwork of the envelope). Only the main-PCB was purchased from Samsung. Even the main distributor was the same at those days: go to
Richer Sounds - The UK's Hi-Fi, Home Cinema & Flat Panel TV Specialists!
I need a service-manual and thus that Samsung CD player model, where the same PCB is in use.
Thank you for your advice.
  • Eclipse CD-101 front view.pdf
