ECC88, warm up time
there is sort of diode transfer function (for AC) between heater and cathode .
when you elevate heater above (or bellow ) cathode (which is usually at near gnd potential) you're approaching horizontal part of mentioned diode transfer characteristic .
Some years ago this threw me out on a fault find in an amp with a 7199, the pentode voltages were well adrift: the circuit diagram showed heater +50V above ground, ideal for the split load; but apparently not for the pentode section. Ironically, in a mistake I discovered making the heater to cathode at -50V cured all problems. So what does one do ?
richy
