Hi BJK,
That's an indirectly heated double triode for audio purpouses.
A plenty of commercially made and DIY-project amplifer using them as driver, or sometimes as preamp tube.
Many tubefactory manufactured and manufacturing this tube.
In the USA it's called 12AU7.
Datasheet can be found here: http://frank.pocnet.net
All the best,
All the best,
Hello Anatech. Well, I suppose it depends on whether you think that 12AU7 is really identical to ECC82 or merely equivalent (drop-in usable). Perhaps 12AU7 is OK for audio - we don't see a lot of American toobs in Europe unless we specifically order them (and pay Customs charges on top of shipping), so I can't comment. It's as well to remember that it only takes a tiny difference on the curves to make a big difference to distortion, so two valves could be equivalent as far as gross characteristics are concerned yet wildly different when second-order characteristics like distortion are investigated.
Hi EC8010,
Well, I was pulling your leg. But you do bring up an excellent point where tube "equivalents" are concerned. I imagine a similar difference exists between manufacturers. Then it becomes whatever the designer used as a "bogey" tube model as to what tube is the best for a particular circuit.
Personal preferences will muddy that water up forever.
-Chris
-Chris
- Tubes / Valves
- ECC82
