Hello,
I don't want to spoil Chalies ACD LADSPA plugins thread with my unrelated problems.
I try to encapsulate a working ecasound line command in MPD to stream my music. But playback fails with
in the ecasound part of the MPD logs.
The command encapsulated in MPD is
The same command in the shell (replacing stdin by a music file) works perfectly.
The same mpd.conf with only -o:alsa as output works and mpd streams music to my laptop speakers.
Googling, I found that it may be that another process has preempted the access to my sound devices. It is strange to ma as typing the command from the shell works, but...
Googling more, I tried to identify which processes could use the sound cards:
I tried killall pulsaudio, but it started again... So I modified /etc/pulse/client.conf
and then sudo killall pulseaudio
But there are still some pulsaudio processes that soon reappear using the soundcards
Last I tried
But I then still have my MPD/ecasound failure: ... Unable to open ALSA-device for playback; error: Device or resource busy
I would be happy to getrid of all pulse audio processes to see if it is the reason or not of my problem...
The distribution is Ubuntu 14.04
Any help welcomed....
JMF
Code:
ERROR: Connecting chainsetup failed: "Enabling chainsetup: AUDIOIO-ALSA:
... Unable to open ALSA-device for playback; error: Device or resource busy"
Code:
audio_output {
type "pipe"
name "DSP crossover"
mixer_type "software"
format "44100:16:2"
command "ecasound -d -z:mixmode,sum -B:rt -b:128 -i:stdin -f:16,2,44100 -o:alsa,hw:1,0 -d"
Code:
@ubuntu:~$ fuser -fv /dev/snd/* /dev/dsp*
UTIL. PID ACCÈS COMMANDE
/dev/snd/controlC0: jmf 4009 F.... pulseaudio
/dev/snd/controlC1: jmf 4009 F.... pulseaudio
/dev/snd/controlC2: jmf 4009 F.... pulseaudio
Code:
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
; autospawn = no
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; auto-connect-localhost = no
Code:
jmf@ubuntu:~$ ps -ef | grep pulseaudio
jmf 4009 2485 0 12:13 ? 00:00:00 /usr/bin/pulseaudio --start --log-target=syslog
jmf 4014 4009 0 12:13 ? 00:00:00 /usr/lib/pulseaudio/pulse/gconf-helper
jmf 5505 3155 0 12:38 pts/7 00:00:00 grep --color=auto pulseaudio
Last I tried
Code:
pasuspender -- sudo /usr/bin/mpd --stdout --no-daemon --verbose
JMF
additional info:
A direct alsa conf to my hardware in mpd.conf works:
Code:
audio_output {
type "alsa"
name "My ALSA Device"
device "hw:1,0" # optional
# mixer_type "hardware" # optional
# mixer_device "default" # optional
# mixer_control "PCM" # optional
# mixer_index "0" # optional
I took the afternoon to port all the setup to the OrangePi, on armbian.
It went not too bad. On armbian, there no pulseaudio... and MPD can drive the two soundcards/amplifiers without any issue.
It went almost straight forward on the Orange Pi (with the preparation and troubleshooting of issues on the laptop).
JMF
JMF
If your device is busy, the mentioned command will tell you the cuprit.
sudo lsof /dev/snd/*
Disabling pulseaudio in a regular desktop distribution is not straightforward, that daemon is rather resilient. But there are ways, e.g. the pasuspender which is reported to work ok (I have no personal experience with it as I use minimal pulseaudio-free distributions for embedded audio purposes).
Since the above works, I suggest you try using an ALSA loopback to connect MPD output to ecasound input.additional info:
Code:audio_output { type "alsa" name "My ALSA Device" device "hw:1,0" # optional # mixer_type "hardware" # optional # mixer_device "default" # optional # mixer_control "PCM" # optional # mixer_index "0" # optional
First, you can temporarily add an ALSA loopback just by typing:
Code:
sudo modprobe snd-aloop
Now run aplay -l. You should see the Loopback listed. Note the card number.
Change the MPD output (shown above in your post) to use that ALSA card as hardware output. Phoman will caution you that the card number may change and he is right in this case. But for testing purposes this is fine for now.
Now you have the input to the loopback, you can direct ecasound to read from the loopback by using the same card number as input. E.g.
Code:
ecasound -B:rt -b:1024 \
-a:pre -f:16,2,44100 -i:alsahw,?,0 -pf:pre.ecp -o:loop,1 \
-a:... etc.
Note that you need to tell ecasound what audio format to expect from alsa. It can't detect it on its own.
Does that work?
Also, here is the portion of my MPD config file where I set the output and set resampling to a fixed audio format using a high quality sinc resampling algorithm:
Code:
# ALL AUDIO RELATED SETTINGS ARE CONFIGURED BELOW
audio_output {
type "alsa"
name "ALSA Output"
device "hw:0,0" # ALSA output used
format "48000:16:2" # audio specifier string; sample_rate:data_format:num_channels
auto_resample "no" # disable alsa resampling
auto_channels "no" # disable alsa from changing the number of channels
auto_format "no" # disable alsa format conversions
mixer_type "software" # optional
always_on "no" # do not try to keep the output connected at all times
samplerate_converter "0" #Best Quality Sinc Interpolator
audio_buffer_size "512" #output buffer size in kB
Hello,
Thank to both of you to provide some information. Now the OrangePi (without pulse audio) delivers music !
I will concentrate now first on the audio part: make sure that all my filtering is as expected, delays on tweeters OK, that the final speakers response is as per specifications.
Then I will have a lot of tidy up and improvements: adjust the MPD/ecasound strams formats (32bits, upsampling if needed...), SOX for dithering, MPD that doesn't work as a daemon, tidy up all the configuration, write the Howto...
I may use your loopback principles for the piping to SOX. Using my virtual device grouping the 2xUSB amps had strange behaviours: sometime it was perfect, sometimes there was some strange digital distorsion. Starting again the track with the ecasound command line could solve or not... At the moment I stream directly to my 2 devices from ecasound chains.
Charlie, your advive to create a bash file to execute the ecasound command in MPD was really good. It does not modify the behaviour, but it is much more easy to manage !
Thanks ! It wouldn't have worked without your help !
This is a steep learning curve for me on at the same time Linux, alsa, ecasound, LADSPA, MPD, headless SBC, DSP...
Best regards,
JMF
Best regards,
JMF
- PC Based
- ecasound in MPD - problem of Device or resource busy
