Good day! My name is Ivan. I use the Google translator so if that right I apologize if where will not correctly translated. Bought the same amp in a failed state with missing electrolytic capacitors in the voltage Converter. Someone tell me what voltage they should be? I have 14.4 V at the input they have +/- 70V and a scheme that I found on them the value of capacitors 63V. Less than actually. Contacted official support sent files schemes but from other devices. My red monoblock.
how many volts in the factory version should be capacitors of the secondary power? Thank you
- General Interest
- Car Audio
- Earthquake PH2000
