Here is the best pic I could get using the ground terminal as a reference. Should I always use the ground terminal when working on an amplifier? Or does it depend on the circuit you are working on?
Thanks again Perry. Is this normal in class d's predominantly or are there some class ab amps that would have waveforms like this as well. Seems as though I have seen a similar waveform before.
