Hi Folks
Can anyone help? I want to export my Krell KSA50 layout into PDF format, so I can mail it to myself at work and print it out using the big hi-res laser there for the toner transfer method of protoyping. I was hoping that Eagle, when asked to print would come up with the Mac printer options window, so I could save it as a PDF, but it doesn't.
Anyone have any work arounds for this?
pinkmouse said:Can anyone help? I want to export my Krell KSA50 layout into PDF format, so I can mail it to myself at work and print it out using the big hi-res laser there for the toner transfer method of protoyping. I was hoping that Eagle, when asked to print would come up with the Mac printer options window, so I could save it as a PDF, but it doesn't.
Jason has installed Eagle on my G4 and used it, but i haven't played with it yet....
It doesn't use the built-in print routines? That is quite strange. I get a chance i'll have a look.
dave
Thanks for the offer Jens, but I would like to get this sorted properly as I intend to use Eagle quite a bit.
Coming at it fresh this morning, I did find the Export command that lets you save a resolution definable bitmap, so I suppose I can just save a very high res version, load it into Photoshop and export it as a PDF from there. It just seems a little clunky, that's all. Still, it will get me going this weekend.
Jens, does the Windows version export PDFs directly, or do you have to post process them?
Thanks Dave, I'll mail you a small layout to have a play with.
JensRasmussen said:I have just selectet the acrobat PDF printer and printed to the printer without doing anything else. It comes out at the right scale and everything, so I think it is a great way of making prototype PCB (I do it myself too)
So with Acrobat (and the Virtual PDF printer) installed, one should be able to print to a pdf -- it would be so much easier if the ap used the standard print dialog which allows this independent of Acrobat.
I played a bit with it last night... does the X11 version of the ap look like the Windows version? Cause it sure is ugly.
dave
If you can't find a PDF printer under Panther (I couldn't), try the following.
With your layout on the screen, click the printer icon,
then the Printer... button,
and click-check the diamond next to Print to file.
Change the file name and/or click Browse... as need to choose the directory to save the file in.
Then click the OK button.
Find and select the first little print dialog box which has probably hidden itself under
some other windows.
Click its OK button and it will save a postscript file.
Double click the postscript file to open it with OSX Preview.
Save the file with Preview to produce a PDF.
You are done!
Only nine steps but enough to appreciate you don't do this often.
some other windows.
You are done!
Hi Pinkmouse,
'Printing' is not the right way to create an output for board production in Eagle.
Instead, try the CAM 'processor' and load a 'CAM-job' for layout output (or just select all the layers that you want to include in your layout print). Then choose PS (postscript) or EPS (encapsulated postscript) as output device, the former will create a printing page, the latter a vector graphics file to include in other documents.
Processing the job (with the board editor window activated in the background) creates a corresponding file in your project's working directory. You can directly use this file to view in Preview.App, e.g. for printing or converting to PDF.
If some of the steps remain unclear (all about CAM output is described in the documentation and the tutorial), just point me to it. I've got Eagle installed and working under Linux, Windows and MacOS X.
Hope this helps,
Sebastian.
pinkmouse said:Hi Folks
Hope this helps,
Sebastian.
Hi Dave,
All versions of Eagle look exactly the same.
This appearance is originated in it's roots under Un*x, using a 'Motif'-like GUI.
The CAM(era) job dialogue solves all issues regarding graphics output. Just treat eagle as an application without a printing option at all, instead use Preview.app for b/w or color previews/prints of schematic and board.
As I understand it, the regular printing dialogue wouldn't make much sense in such an application, as what you print is not (neccessarily) what you see. In your working window (schematic or board), all additional layers (e.g. '*Origin') and things like mounting grid lines/dots are not neccessary on a draft copy. And such things would definitely look disturbing on a copper board.
Ciao,
Sebastian.
dave
Ciao,
Sebastian.
johnf said:try the following....
Tried that... took it into illustrator. Generated what looks to be a decent vector file -- it had some problems with the text thou.
dave
Re: Re: Eagle under X11(mac) and printing PDFs
OK tried that... it works too -- didn't concern myself with the layers... the text now is still screwy... it has been poorly vectorized (ie a bunch of lines as opposed to actual text in the print file -- the print file was a different font -- the text in the print file more closely resembles that in the screen presentation in Eagle -- the Cam file is not close.)
I take the screwy text back... the text in the file pinkmouse sent me has the same problem (ie text on top of text)
dave
sek said:Instead, try the CAM 'processor' and load a 'CAM-job' for layout output
dave
Thanks guys.
It does seem all a bit clunky, but that's probably down to the legacy of pcb design software in general rather than this particular package.
I did get something useable out last night to experiment with, but it took about 30 steps. I will try the CAM job next time and see how that goes. I'm sure it could be easier though!
The last time I messed around with Eagle's fonts, it allowed you to specify a nicer-looking proportional font. Unfortunately when it came time to output things (to send to your printer or PCB manufacturer), it substituted an older, emaciated vector font and placed your text not quite where you wanted it.
Have you tried sticking to the old vector font with an increased width?
- General Interest
- Everything Else
- Eagle under X11(mac) and printing PDFs
