Original Dynaco said that it could provide the extra 1 amp per winding but this was an exaggeration. Current through the outputs was also exaggerated in their specs, realistic numbers are 40ma per EL34.
A realistic value for each 6.3volt winding is 3-3.5 amps tops.
Daniel
Edit: I just saw that you won't be using the 5 volt winding, so this will give you some extra elsewhere in the transformer. Try your circuit out and see how hot the transformer gets. If it's too hot to put your hand on it, I would ease off a little. You can always put a small filament transformer under the chasis.
Daniel
Humm, in stock form with nothing plugged into the front your running 3.45ma all the time.
I know the power tranny's in 70's run hot but I've still yet to see a dead one. (yet that is)
Was hoping that not running anything off the 5v winding may help some as well. (yah you saw it)
We'll see how it goes.
Thanks,
keg
Thanks,
keg
- Tubes / Valves
- Dyna ST70 PWR Tranny 6.3V Crnt Spec?
