Dual Ten for CRV
Disabled Account
Joined 2013
Hi everyone
I am looking to put two 10" tapped horn in my CRV, the available space i have for the cabinet is 13*33*30. I was wondering if anyone know of any 10" driver that is suited for TH. I am limited to 500watts of power for both drivers and i am looking for a flat response from 35hz to 100hz. I was looking around the forum but no luck. My budget for both drivers is $350.00
Thanks in advance
Flat response frome 35 to 100 IN a vehicle..... Sounds like a job for a sealed box.
Anything that is flat to 35 OUTSIDE of a vehicle will have a terrible hump centered at the low frequency cuttoff due to the cabin gain once you put it in a car.
Generally this starts around 55 hz and is around 10-12 db/oct boost as you decend in freq
Disabled Account
Joined 2013
I am looking for something that have more output than seal or ported
If the response is not flat NO PROBLEM.
GM
Joined 2003
No idea about driver cost and at ~133 L net Vs your ~169 L gross size, it in theory can be folded up to fit. This driver's specs isn't conducive to a real flat sim [it wants to be this big just for one driver], though it should be somewhat flatter than predicted and you'll probably want to EQ it to boot. 120 dB from ~28-108 Hz @ 500W sitting on the ground outdoors. The compression ratio is high, but you're not driving it anywhere near its 1400W peak rating, though your guess is as good as mine as to whether these drivers are built good enough to handle it.
GM
JBL GTO1014D 10-Inch Die-Cast Dual-Voice-Coil Subwoofer:Amazon:Car Electronics
More like 150 bucks. The gto series is a bargain.
The tapped horn would be MUCH louder down low, particularly at the resp peak of 35 hz, but the flh would likely be flatter, and still very loud, with the benefit of already being folded and having plans available for easy construction.
Ive built 3 autotubas, all with the 8s and been cery surprised with their output
Hi Beat Street,
This suggestion is smaller than what your Requirement stipulates and could cut your Budget in half if they still are available, of course:
b :)
Bjorno
Would it be ok to remove the mouth opening and place as indicate in the attch picture. If it can be done what would be the cutout size.
Yes but if the choice is to place the Terminus symmetrically above the two Drivers of some reason( IMO no advantage) you have to enlarge the cabinet a bit.
Size of the Port: See the Picture:
b :)
Disabled Account
Joined 2013
GM
Hi Gm thanks for your help with the tappedhorn but i will be going with the one that Bjorno did.
