Dual rail from trafo with no CT?????
Amp?
But you have to watch the voltage being dropped by the 3 pin regulators, more drop compared to the unregulated rails = run way hotter.
_-_-bear
Hi Bear,
I was checked it.
Using regulated PSU as source = 12.3 Volt DC
TDA2050 pin 5 = 5.9 Volt
TDA2050 pin 3 = -5.7 -5.8
And feel tight bass from mycMoy preamp (using NE5532P).:p
And the TDA2050 is just little warm for 4 hour playing
In my opinion, the two best ways to use a single output transformer to make a power supply for an amp are:
1. Try to determine if the single output transformer is made from a dual-secondary transformer with paralleled secondaries. This is surprisingly common; I'd guess at least half the transformers I have salvaged are made this way. The two lead wires from the transformer will disappear under some varnish-saturated paper where they are connected to the (stiff, solid copper) windings. Carefully cut away that paper (in a way that you can reverse the surgery later) and see if each lead is soldered to one or two copper windings. If two, then jackpot! You have a dual-secondary transformer. A little surgery will separate them, then you can connect them in series instead of parallel to get a center-tapped trafo.
2. Use a BTL - Bridge Tied Load - configuration with two amps. This way, there is no speaker current flowing into "ground", it goes rail-to-rail not rail-to-ground. That means that you can very effectively use a single supply along with a relatively weak phantom ground (via voltage divider) for the input side. The usual bridged amp considerations apply like doubling of load current (halving the effective load impedance), etc.
