http://www.proex.eng.br/DSPOWER-2040-CRV4C.pdf
On page 19 there is recommended schematic for class D output stage.
If you search for DSP with analogue outputs - take a look at ADAU1701.
DSPOWER-2040-CRV4C
Can it be controlled with 485 PC?
Can I input and output analog signals?
How much is it?
Can you buy it in China?
Thank you
DSPOWER-2040-CRV4C
How much is it?
Thank you
There is no serial communication. It is for stand alone application.
Yes, you can input analog ou digital audio (s/pdif). This module output analog audio and PWM modulation.
I paid U$ 48.00.
Can you buy it in Brazil only. (not chinese product)
This is dirtier than Chinese. The gain of an open-loop PWM amplifier changes with supply voltage sag. The transition from discontinuous inductor current (DCM) to continuous inductor current (CCM) is a source of low volume distortion. The whole idea of tri-level open-loop PWM amplification is aimed to 10% THD.
edit: And yet, it is way to go for AC power inverters.
I paid U$ 48.00.
Thank you
No RS485 is not good debugging
Thank you
what to debug, software?
You not need write software for this module.
Eve said: "The gain of an open-loop PWM amplifier changes with supply voltage sag." Yes, the power is proportional to the supply voltage.
I use estabilized power supply.
- Class D
- Dsp board for class D amplifier
