I think jerome has covered the important points about c5 so I will keep my answer short. It makes my senses tingle, but it works. Although there must be another way to get the same result, if I couldn't find it I would at least put a 1 ohm resistor in series with the capacitor.
You describe your speaker as dynamic, detailed and smooth. This sounds like a good combination and I'm glad you found these. The hard work pays off
Hi Allen,
Finally C5 2.2µF + R10ohm makes the right impedance in high frequencies; however I had some works on others parts of the filter to get the same nice listening result and Fx is displaced to 1.4kHz.
Anyway thank you for having pointed my mistake!
transfert function:
transfert function:
