For that type of signal, there will be no visible difference if the trace is intact. There will be a difference if you're looking at the base of the driver transistor and the gate resistor or if you're looking at the signal after the gate resistor.
Are you looking at the signal on the emitter leg of the driver transistor and the end of the gate resistor that's not connected to the FET gate?
- General Interest
- Car Audio
- driver signals
