Just noticed that the originally proposed Tang Bands have an Xmax of only 0.5mm!
Why would anybody even build (or buy) such a driver???
Example for a use
https://www.youtube.com/watch?v=tAmwCrIyw2g
Thanks for the advice. Seems like a interresting alternative to the scanspeakIt all depends how loud you need to go. >100dB (as mentioned) for lengthy periods will endanger your hearing. For sensible levels, look at the Monacor msh 115.
I was thinking along the lines of the SS 10F or the Vifa (both 2.6mm) also mentioned elsewhere.
Nils Ollerer, FoLLgoTT member here has interesting use of dome mid for his home theater, looks like he has plenty xmax and spl...
http://www.diyaudio.com/forums/mult...narrow-directivity-horbach-keele-filters.html
see his projects
see his projects
You'd have to live with the small sweet spot though:
The sweet spot is not large. Since directivity gets much wider under about 800 Hz the sound changes under angles. The lower frequencies stay nearly constant in the whole room (because of reflections), but the higher doesn't. So this speakers must point directly to the listener. And it is clearly a one-man-speaker.
- Driver for vocal
