Hi Ian,
Thanks, good news. So without external MCLK, I need a USB Xmos with an mclk output. But an external MCLK would work too if I feed with it the USB Xmos then the PCM and the DAC if I don't use the bclk output of the PCM to the DAC board... (the last seems illogical, but I'm asking in the case of a home mclk board stacked just above the dac for short connections without Fifo to rule all the device with its Crystal... I understand this Crystal must be 45.x or 49.x because the Xmos : yoour answer !)
I have maybe miss something because my English: I'm on the list for a PCM boards for 2 months (and I'm moving today for 2 boards) without FIFO: do I have to paypall you or wait an invoice payment from you. I don't understand if this is due because you are very busy or if I did a mistake in the procedure... sorry to take your time with 2 cents logistic questions
Hi Eldam,
I confirmed that the new generation of XMOS USB works perfect with/without isolator for my I2S-PCM board up to 384KHz. I have a TDA1514A too. The sound was amazing playing 384KHz music for my iMac.
The new generation XMOS is in BGA package, it's using 48MHz system clock, the performance could be much better than the old generation for the processing speed and I2S timing. I would recommend it and the the Amareno.
I still have some I2S to PCM board PCB, but I run out all FIFO KIT and clock board. If there are enough order of PCM board, I may consider running another GB for I2S to PCM board in advance. Please let me know.
Regards,
Ian
Thanks Ian,
I can buy the sockets and solder it myself, thank you.
Hi Eldam,
For my I2S to PCM board, MCLK can go any speed from 32 to 64Fs. But you have to make sure it the same MCLK of your I2S source, or you have to include a FIFO before the PCM board to go a ASYNC operation. This MCLK can apply to your DAC too if it really need a one.
U.FL sockets are reserved optional and usually need to be assembled buy DIYer. Please let me know if your really have problem doing that.
Good weekend.
Ian
The process is normally alongh the lines of this:
1. interest list builds up
2. wait
3. when Ian has both time and sufficient interest he'll start building up stock of PCBs and parts and assemblies then open up the GB. This will come with a new form/spreadsheet.
4. Fill the form out with the final order (can vary from from expression of interest) and send to Ian.
5. Follow any other instructions that Ian provides when he announces GB.
We're currently in the 'wait' phase but Ian's earlier comment was that he might run a limited GB for the i2stoPCM board only as stock and interest (and his time) for the others are making it not worthwhile
Hopefully that's made the general process clearer? Let me know if there is anything that is unclear and I'll try again ... no stupid questions here, I'd rather spend a few minutes typing rather than have confusion rain and have you miss out on an opportunity
Dear Ian,
May you add for the input of this board uf.l trace like you did for the input in your next production please ?
Not sure if it was understood from earlier posts, but just to be doubly sure, there is input u.fl on underside of the i2s to PCM board, but they're unpopulated so you need to solder them yourself.
Chris
Hey Ian,
Have one of these still in the box, just wondering how you go playing 44.1 without up sampling or resampling. Down sampling I can deal with but up sampling hasn't ever sounded right to me, loses something in translation.
I think I grasp the TDA1541 will play up to 192 on a "normal speed clock" and from 88.2 to 384 on a half speed clock? So I am just trying to grasp if the clock used is the si570 can it adjust to half speed if playing above 192 or could we use a divider to halve the clock sample when sample rate is above 192 which could be watched or set from indicators on wave io?
Thanks,
Drew.
Hi Drew,
Both PureMusic and Amarra can do bit-perfect playing at music's native Fs. I2S to PCM board is also running at pit-perfect mode doesn't do any up-sampling or re-sampling job. My configuration was iMac-PureMusic (or Amarra)-USB-FIFO-Clock board-PCMboard-TDA1541A( simultaneous mode ). With similar system, you can do anything which you prefer.
Both Si570 clock board and dual xo clock board (with 45/49MHz XOs) can drive the PCM board and DAC running up to 384KHz. Full/Half speed can not be adjust automatically with current design, it doesn't change the SQ according my listening test. But if your really want, you can try some external logic, I don't see there is any problem.
Regards,
Ian
Ian, Is not the PCM 192 khz max ?
PCM board runs up to 384KHz, even with 45/49 MHz MCLK. 192KHz is not the max.
Ian
I am pretty sure they are DIY. I did similar once, I got longer u.fl cables and cut in half and used each half. That way 2 longer cables made 4 shorter u.fl to wire terminated leads.Is someone knows please where can be found the wires seen on the photograph of Ian about him last USB Xmos: one side uf.l connector, the other side plug for jack connector seen on most of the XMOS boards ?
Is this DIY : expensive uf. sacrified on one side ?
Chris
A question I've been meaning to ask of those who...
know much more about high-speed signal transmission and impedance-matching than I...
When interfacing I2S data and clock signals between a board with u.fl sockets on one end and a header on the other, is it better to use a cut u.fl cable as Chris describes below soldered to the header end (preferably after removing the header and going directly to the board) or is it better do a 'makeshift' u.fl socket adapter and use a stock (un-cut) u.fl cable?
Inquiring minds are waiting for your responses!
Greg in Mississippi
Greg in Mississippi
Greg in Mississippi
I'd vote for either/or really. Depends how cleanly the u.fl makeshift can be connected to the signal and ground pads. If it's pretty hard to attach the u.fl socket then probably no meaninful difference really. If you have a gnd plane on that side of the PCB and you're able to scrape solder mask away you may be able to get an improvement with u.fl. But be careful with the socket, the underside has an exposed part directly under the signal termination in the centre where the signal could short to whatever is underneath so try to keep that solder mask under that to ensure you don't short signal and gnd.
Greg in Mississippi
The return signal path has to be the closest to the signal wire : so flat wire with one gnd (G) wire for each signal (S) wire à la : GSGS etc . It could be also better to put a larger flat cable to put a wire with no signal (N) between a S and the G used for the other S : like that SGNSGNSG: the signal return go always to the closest path but with that flat cable arrengement with a space between each GS : there is maybe a better separation of the I2S signals : if I'm wrong specialists will correct me !
BUT... with UF.L wire and connectors : G&S are always very close to each others with a constant impedance matching & the coax arrengement provide a good insulation like the connector provide on the pcb to use few soldering... It is the the way now diyers should have to go with RF. And of course as already said with r=the shortest wires... BTW if someone have a link or ref for Mouser for ufl wires, I have some difficulty to find it in the french Mouser pages...
that's my simple understanding after al the reads on diyaudion....WIth RF, too much diy pcb device make the econmy with it or in the worst case wa can see good design but unluckily wasted by some bad terminal layout with : GSSSS
Hi Ian
I would like to convert my AD1862 DAC to non o/s. Could I buy an I2S to PCM driver board from you.
Peggy
Please put your name on the waiting list of the GB thread. I'm considering running a GB for PCM board earlier.
Regards,
Ian
Hi all,
if anyone was interested in the custom Laptech crystal
http://www.diyaudio.com/forums/grou...hronous-i2s-s-pdif-fifo-kit-group-buy-70.html
please add your name in the wish list at
http://www.diyaudio.com/forums/digital-line-level/203511-any-good-tda1541a-dac-kit-96.html
The minimum orderable quantity from Laptech is 5 pcs for each frequency.
When that quantity will be reached I ask Laptech for a quote.
Andrea
As promised, the list of interest is started.
http://www.diyaudio.com/forums/digi...-jitter-crystal-oscillator-4.html#post4057057
Hi Ian. I asked you by email, but I think this will be interesting for someone else.
Is it possible to run TDA1543A/44/45A with your I2S-PCM board?
Instead of regular 1543 version, 43A/44/45A are not I2S, but (from datasheet):
Compatible with most of the Japanese input formats: time multiplexed, two's complement and TTL
These chips like 1543 have only 3 pins for use: DATA, BCK and WS. As you can see there is no separate Data L and Data R pins. How to connect in this case to your I2S-PCM board? Or it is impossible? Thanks!
Hi Bisesik,
All of them don't support simultaneous mode or other "PCM" format. So, I don't think you can use the PCM board in this case. But FIFO is possible.
Though it's not I2S input, but I'm not sure if it is "SONY" format or other Japanese format. FIFO support all other three formats besides of I2S,
left justified,
16 bit right justified,
24 bit right justified FIFO input format"
Maybe you can give a try.
Please refer to document "I2S FIFO Firmware V3.80 Upgrading" for setup detailed.
Regards,
Ian
- Digital Line Level
- Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver board
