Alternatives
Here is a less expensive alternative.
McMaster-Carr
Or just buy some drill bushings and make your own from a small block of wood using a friend’s drill press one time. N.B., also use the drill press to press the bushing into a slightly smaller hole drilled into the block.
McMaster-Carr
To drill holes to the center of a wide panel using a drill press, a radial arm type would be needed. They are much more expensive than one you have in mind.
Regards,
WHG
McMaster-Carr
McMaster-Carr
Regards,
WHG
