Hi!
I'm putting together a high efficiency speaker system. Nothing drives me crazy more than AC hum. When you are using ~107dB altec drivers AC hum is hard to avoid
This whole thing is just a crazy idea
I am considering putting together a 12v+12v battery plant.
I wanna run the horns on a Pass mini A with 12+12 rails (total 1.5A draw). This should give me ~7-8 watts on a 107 dB horn. adequate IMHO.
The woofer is not yet specified but I expect to use something around 95-97dB. I'd like to find a nice sounding bridged solid state AB design to get the most out of the rail voltage of 12+12.
Is it possible to get decent power out of such low rails - that sounds nice? If so, could you point me in a direction.
Thanks a lot
Thanks a lot
there is a bridged ClassA amp somewhere on this site.
It is from a recent magazine article. One of the designers regularly posts here. I seem to recall rails around 20V. It may work at lower voltage.
BTW,
a CRC or CLC supply removes much of the mains hum/buzz.
You should not need to go battery power to eliminate hum.
BTW,
