It looks like an ordinary 250 volt polyester / aluminium non-polarised cap. The value is blurry, but by the size it is probably in the range 0.5uF to 2 uF.
It doesn't seem to have markings for metallised poly types (eg. MKT, MKP, MMK, PP). It would be OK for audio coupling, eg. anode to following grid where V+ is <= 250 volts, or in a low voltage circuit.
Its a 10µF 250v. The salesman gave me when i ask for a metallised cap. Can you compare it with a MKT because i have 4.7µF Philips MKTs. But i cannot find more capacity of MKT and somebody (AndrewT) said "use 10µF for subwoofer amp DC blocking"
Should i use that one or my Philips 4.7µ MKT?
- Chip Amps
- Does anybody know that cap?
