Hi Folks,
I have a version of the Hitachi-datasheet Mosfet power-amp (the Mike Creek/ETI/R&EW version) which has been solid as a rock for the past 25 years. Unfortunately one channel has just started to become a little unstable, so I'm going to treat it to a (probably well deserved!) service and replace things like caps and maybe resistors.
Do I need to worry about replacing the output devices? I'm kinda hoping not as this would be quite expensive - each channel uses three pairs of devices (2sk134's/2sj49's).
Could I leave alone the other transistors, too - none of them seem to be readily available anymore? (though I'm sure substitutes exist).
Thanks,
Tony
Thanks,
Tony
I am sure someone here could recommend a replacement for your MOSFETS Matching might be an issue, but not as hard as you think... and not as important as some would want you to believe... all depends on the circuit.
Semiconductors, in general, die because of heat. Every 11 degrees C in operating temp cuts their life by one half. Except for some minor effects in the silicon itself; these wearout mechanism are all about heat induced stress. The die wants to rip itself from the metal base. the whisker (connecting wires) want to jump off the die etc...
Replace your caps... if you have carbon comp resistors... replace them all. See if that clears your problem before you mess with the SEMI's.
EDIT: you should replace your caps and res's on principle. But, don't forget to reflow ALL your solder joints as you go. They get weak as well from the same kinds of thermal induced stress. They are often the culprit when you encounter intermittant problems.
Medium and high power semis (especially TO3 ones) die of heat induced stress, but usually last a VERY long time unless there is some fatal flaw. For TO3, this is normally mechanical - overstressed case when mounting, bad thermal interface (silicon grease that has turned intopowder and crumbled away').
Plastic cases in general, and older small signal TO92s and similar, have a problem with corrosion - the pins corrode cracking the plastic to metal interface, eventually, the interface to silicon gets contaminated. Heat makes it all VASTLY worse. If you see coroded pins o the small signal transistors, replace them.
Finally, there is one more thing that can end up in small signal semi death in amplifiers. Very often, the input LTP transistors do not have sufficient Vcbmax to span the supply rails that this stage is using. This is because most high gain transiostors are not high enough voltage. Under normal circumstances, this is not a problem, but in transient conditions (power up, power down, in some designs clipping or current limit) or if the amp ever had a fatal failure, such as a shorted power transistor on the output, thses can develop very odd problems - crackling noise, leakage, low gain.
One other problem that I remember that fits the description, is contamination of the flux used in the solder. In two cases I had, the cure was do thoroughly clean the PCB (in one case I figured it out only after I had completely rebuilt the whole PCB with brand new coponents )
Thanks guys for all your responses,
It sounds like it would be a good idea to replace the critical caps, though given that it won't cost much more and I'll have to dismantle the amp anyway, to also replace the other caps, too.
The resistors are all carbon film, so I'll replace these, too. In the process I'll make sure I go over the solder joints for components that don't get replaced.
A visual inspection of the trannys, output devices and the TO92's, seems to show them in ok condition with no obvious looking corrsion and the thermal grease seems ok, too, so I'll leave all of these for the moment.
However, Ilimzn, I don’t really understand the bit about voltage ratings of the input LTP. The input pair are 2SA872’s where Vcbo is -90v. The supply rails are + - 56v. Do you think this would cause a problem?
The amp actually sounds as fine as it ever did. The reason I think it maybe becoming unstable was when I connected it to a new pre-amp I've been building there was a buzzing from the speakers (sounds like 100hz but could have been 50) which I initially put down to an earthing mismatch between the two. The buzzing was quiet and would come and go. I did end up using this combo for a week or so whilst playing around with the pre-amp. Then later, the buzzing got louder and some wierd things started to happen whenever I connected the pre to the power (spkrs disconnected) like the CD player (and also the DVD) seeming to lose the ability to read discs. Perhaps more tellingly I have a touch-controlled light dimmer fitting in the room and it would go from full bright to full dim as soon as the two were connected! Possibly the new pre-amp is unstable, too, but see below.
However, on reconnecting the original pre-amp (or the other pre-amp I have, a Naim 62), the buzzing still comes and goes, which seemed odd because they’ve both always been fine before. This was the case even before leaving the new pre-amp connected for a week or so.
I borrowed an oscilloscope and, although I don't yet know how to use it properly, have made some comparative tests against the other channel (they’re monoblock amps) and also another power amp (inputs shorted on all the amps). With the probe measuring the voltage rails on the good channel (and the other pa) I see a clean triangle-type wave with the scope on 10ms/div, which I guess is the ripple voltage? On the poorly channel the wave form is about 30% lower in amplitude but very fuzzy and 'thick' like it's been drawn with a thick marker pen. On altering the scope setting to 2us/div I see an irregular wave form. The other channel doesn’t have this - unless I also power-up the poor channel in which case the irregular waveform reappears on this channel, too.
After about 10-15 mins of idle the heatsink on the good channel remains more or less cold whereas the poor channel is warm. Lastly, on the poor channel the resistor in the zobel network has started to burn out, though at the moment it still measures its original value of 10R.
Tony
Tony
Davidsrsb, I'll definitely look at these two points - blowing tweeters would be very bad indeed
Johnnyx, thanks for this, a very interesting thread with much to digest, though I don't pretend to be able to follow the discussion on actual design details
The gate resistors, which you found to be significant in your amps, are 220R. I'm coming to the conclusion that the amp has become flaky due to simple ageing of components and solder joints rather than component values or physical layout, given that it has worked very well indeed for the past 25 years. So I guess it's not surprising that it's getting a little tired
Tony
Tony
I'd encourage you to replace the resistors with good metal film ones and the electrolytic caps with new ones.
Leave the other caps alone (IMO) unless you know them to be bad.
Then, recheck your amp's performance.
Give us your results here and we can help you look at other possibilities at that time.
- Do mosfet output devices age?
