DIY sub with sumo A II
..my intention is to use it as a "party" woofer..
For 'Party' use I vote for using a 50 L closed box.
b
1(1)
pic
Nothing holding it together just placed together
Here is the side mounted, and rear cover is being cut.
most of back panel made, still not mounted.
The inside:
Here is it with the front.. it is not mounted yet
progress
Everything is moving along :D..
putting in trafo
Switch
inside with trafo mounted (standing on the side), and last hole for fuse holders is drilled..
