You can get turrets and eyelets in various shapes and
sizes. You can rivet them in and sand it down to
a smooth and low profile.
Won't pads on the pcb suffice?
Untitled Document
Welcome to MEHTA EXPORTS - There is no substitute for Quality
The problem with pads that they are not meant for switch contacts.. will worn out fast ,
Using turrets is an idea ,any turrent come like a rivet?
something related i am searching.
something like i will plug in silver rivets and use .
I have developed the tight coupling arrangements .
Use any plastic as shaft.I am testing with a refill .Stopper is a piece cut from ball pen and glued to shaft with super glue.
once fitted the spring is compressed ,tries to expand and keeps the wiper and contact boards tightly held.
bigger image
Bigger image is hereI bought this.
DACT Type 21 Stepped Attenuator Potentiometer 100K 2A3 | eBay
I replaced the Alps Blue velvet in my pre-amp. It sounds great, better than the Alps but i don't know how long it will last. Time will show. I recommend to give it a try.
The sound has become much more clear & dynamic.
Vassilis
Vassilis
