https://www.diyaudio.com/community/threads/diy-biamp-6-24-crossover.357657/page-70#post-7437609
Elwood625 however is writing about this filter being unity gain in the pass band:
https://www.diyaudio.com/community/threads/diy-biamp-6-24-crossover.357657/page-70#post-7437843
Anyway, I guess all is sorted out.
What I was thinking about by “drive” is the ability to drive a lower impedance than the normal 10kOhms or more, like the old (inverting) “Otala-Lohstroh” amplifier.The circuit is simuilar, if not identical to the B-1 NuTube. That is the output impedance is in the vicinity of 150 Ohms if memory serves me well.
I plan to do a similar thing, driving two bass amplifier per channel for four woofers. It is a Parasound power amp and I have no fear at all.
I've been using the green bipolar electrolytic 10u/25V MUSE BP DC decoupling capacitor at the input buffers (where it connects to the 1Meg bias resistor to Vref. I've built three boards with them, and found that sometimes (perhaps 20% of the time) there seems to enough leakage current through the cap to 0V ground through the input POT to drag down the bias point for the top Jfet to around a couple of volts instead of Vref. I've found that it is fixed by replacing with smaller value/higher voltage same brand e.g. Muse BP 1u/50V. I searched this thread and not been able to find a similar occurrence so just wondering whether anyone has noticed this issue or it's just me. I've tried measuring leakage current through the "faulty" caps out of circuit with ohm meter but they seem to show up as open circuit which is what they should be. Weird.
Update: I decided to measure cap leakage current by using a 9V battery through a 1 meg series resistor also in series with a 100 ohm shunt resister to measure the voltage in order to ascertain leakage current values flowing. Testing my batch of Muse 10u/25 caps, I found that slightly more than half of them had remnant leakage of around 5uA after about 1 minute. The others showed no leakage in this circuit after about 30 seconds. I'll therefore select the low leakage ones for this position (or better perhaps smaller uF values), while the others 10u/25V are ok for output dc blockers. Not sure if my batch is representative for the brand or if they are dodgy production (they were quite cheap from china).
Possible answer to your question/problem.
From Nichicon datasheet https://eu.mouser.com/datasheet/2/293/e_ues-3082323.pdf
"Leakage Current※: After 1 minute's application of rated voltage at 20°C, leakage current is not more than 0.03CV or 3 (μA), whichever is greater."
the max is then 0.03CV for 10u/25V or 7.5uA which would drop 7.5V through the 1meg resistor and mess up biassing of the top Jfet on the input buffers.
Perhaps 1u/25V could be a better choice for the input buffer to get more more reliable biassing.
The NP schematic shows 0.1uf on the input. Not sure why 10uf is in the BOM.
Using an RC filter calculator, I'm not sure whether we use the 1k or the 1M ohm for input impedance. Assuming 1meg and so with 0.1uf gives cut off at 1.5Hz. So we can probably go comfortably lower than 10uf!?
I believe papa once stated 10uF a typo.
Anyway, use 1 Meg for the calculation.
Check also out https://en.m.wikipedia.org/wiki/JFET#:~:text=Because a JFET in a,as input to the gate.
I have not seen this issue addressed here. Lots of folks using this for a subwoofer xover. If using a single sub, as I am, the L and R must be summed and then only one channel of the xover will suffice. Is there a nifty way to do this in the circuit of the xover, or should I just hang the summing parts off the input RCA's before the xover? I'm wondering if they can be summed behind the input buffers by simply connecting one channel to the other. Will the buffers serve to isolate the summing from upstream stereo signals?
I recently decided to upgrade my 6-24 crossover by replacing the J113 JFET's with LSK170's purchased from the diyAudio Store. (as recommended by Nelson in several posts)
The quad sets of LSK170's from the store are specified as having Idss of 8-11mA. The parts I received had measured Idss values of: 4.7, 6.5, 5.3, 4.9 mA All parts well BELOW the 8-11ma Idss store spec. The J113's I am replacing all measure 7 - 8 mA Idss.
QUESTIONS: Should I return / exchange these parts ? Or, use them at say a low bias of maybe 4 mA ? I was hoping not to have to change the existing 100 ohm bias resistors.
NOTE: I measured all the LSK170's using the procedure outlined here:
https://www.diyaudio.com/community/threads/diy-biamp-6-24-crossover.357657/post-7099039
I tested with VDS set to 10V per the LSK170 datasheet.
Robin. I found your post when researching how I might be able to implement a Linkwitz Transform for my sealed box woofer, by using one of Nelson Pass’s ASP boards.Where I am currently stuck is that I think that the opamp in the linkwitz circuit provides gain. Also I am not sure if this would work at all with the unity gain operating J113’s?
My question to the experts out here is whether it is possible to apply the Linkwitz Transform in the same 6-24 circuit using J113’s instead of the op amp?
I’m stuck in the same place you were. That is “I think I need some gain”, but only unity gain on this board.
Did you find a way to do it?
Curious as well, I have my finger hovering over the add to cart button on some of these super shiny matched jfets.I recently decided to upgrade my 6-24 crossover by replacing the J113 JFET's with LSK170's purchased from the diyAudio Store. (as recommended by Nelson in several posts)
This article by Nelson Pass may help with your decision.
- DIY biamp 6-24 crossover
