DIY 2.1 System - Eekel's Mini + Dayton Audio RSS210HF-4
Hello All
I will start here to present my current status of this DIY project: Eekel's Mini + 8" RSS210HF-4 Subwoofer.
The plan is to go all active. Thus, I will make my own version of thee Eekel's Mini with integrated Hypex AS2.100 amplifier (master + slave). I will have to change the port configuration from round to rectangular in order to accomodate the plate amplifier. Also I plan to put polycarbonate covers on the XOs so I can see them directly from the outside... niiiiice :)
The subwoofer I get a preliminary design of 17,6 liter closed box with a QTC of 0,634 and F3 of 48,77Hz... I would appreciate if you could comment on this also! All of you who are far more experienced than me for sure...
I will start next weekend and I will put the photos here so I can share my work.
Best Regards
André
News on the construction!
So I made a template for each crossover, treble and bass, in order to study best component placement and this is the final result! :D
Thank's a lot Wolf... I see that there is considerable difference between each driver, although being the same. I generally assume this to be a fail e quality control, no?
Meanwhile I have been searching a few other options for the subwoofer and it appears that the SEAS D1001-04 L26ROY would be also a good choice, which also fits my budget!
I am using UniBox to model the sub and I come out with a closed box:
Design by Vb and Q Physical Vb24,2lAbsorption, Qa20Leakage, Ql30Alpha, a3,389Vb25,7lFb46,05HzF350,12HzQtc0,649Response peak0,00dBPeak atnone
WHat do you guys think? I want a "stiff" bass but still have some little boominess... Generally I tend to like subwoofer with great "kick" but that can go low without being to boomy...
