There are 2 10 ohm resistors that sit behind the transformer. The board locations are R51 and R52 I believe they are 10 ohm resistors. Does anyone know the wattage on them??
i know this is a tad un-orthodox, but i am looking for that amp, if it is a gen1 with the extruded/milled case in just black.......perhaps you could let the owner know?
I'm not sure about this amp but it's normal for many amps that use this basic design. If it has no output and the relay is engaging, the relay could be defective of you may have a broken leg on an inductor.
