Can i used a 1n4001 in place of 1n5818?It is for the power supply of an ESP-2
H Hexhclass Member Joined 2010 2011-08-28 2:54 am #1 2011-08-28 2:54 am #1 Can i used a 1n4001 in place of 1n5818?It is for the power supply of an ESP-2 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-08-28 2:56 am #2 2011-08-28 2:56 am #2 Probably not. The 5818 is a high speed diode with low forward drop. The 1N400x diodes are likely to run MUCH hotter and are likely to fail. ••• More options Share F fcruz Member Joined 2011 2011-08-28 5:42 pm #3 2011-08-28 5:42 pm #3 a look in the datasheet Attachments 0swl0u9yxwszejqog8artdo5rk7y.pdf 74.4 KB · Views: 29 ••• More options Share F fcruz Member Joined 2011 2011-08-28 5:47 pm #4 2011-08-28 5:47 pm #4 a look at this Attachments sb160 diodo.pdf 51.1 KB · Views: 29 ••• More options Share H Hexhclass Member Joined 2010 2011-08-28 6:04 pm #5 2011-08-28 6:04 pm #5 so what do u think? should i take the chance.The 1n400* and FR51 is all i have for now.I will be getting some others soon .i will list them later ••• More options Share F fcruz Member Joined 2011 2011-08-28 6:21 pm #6 2011-08-28 6:21 pm #6 not not see the datasheet for ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link
