Digital design
Joined 2009
Sorry Bobi.
I'm testing the driver board with an
Amp that uses the same driver board, but 16 MOSFET
per shoulder, the customer told me the model number is, DC audio 9k.
I`m trying to upload a picture, but I keep getting a failed error.
I`m sorry I did not mention the change in testing.
thanks again.
Joined 2009
Not knoing what to do. I pulled out my 50 khz fluke out of the closet,
just to rule out the scope. guess what the fluke scope works just fine,
I tried it at diffrent signals ranging from 50hz to 100 hz, and all fine.
16 of the 32 pads have a good square signal at 5.7 votls.
how can I test the other 16 pads to make sure they are OK before
I install the mosfets?
It's not quite as easy. You need to supply voltage to the high-side of the driver ICs. I use a 9v battery. The negative terminal of the battery will go to the VS terminal of the IC. The positive terminal of the battery will go to the VB terminal of the IC.
If you are using the fluke scopemeter, you can measure the signal across pads 1 and 3 of the FETs. If you're using the other scope, you'll probably need to make a few other ground connections.
Joined 2009
Looking at the PDF file typical circuit of ir21844 I see there is a diode between vcc and vb, the cathode is to the vb side and the anode to the vcc side, applying voltage to the
Vcc will provide voltage to both the vcc and vb, while applying voltage to vb will only apply voltage to vb, Is that what I'm support to do?
