I did only write LM3886 and got zero hits from dot com Not so clever search function.tiroth said:Perhaps there is a problem with your browser? They do indeed sell LM3886T and TF...
I am using IE 6.
Then there must be a browser related issue. When I search for LM3886 I get LM3886T and LM3886TF as results. In fact I think Digikey has one of the best parametric search tools of any major distributor, although their drill-down method can't begin to cope with the size of their catalog.
For instance try "fc 50v 10uF". You should get the four types of Panasonic FC electrolytics that they carry.
You had problems with mozilla? I just tried your search with mozilla, and it came back with the expected result of the T and TF versions. So, its not the browser itself. It must be something else.
P.S. - I've been using mozilla to hit digikey for over a year now, and don't have any problems.
- Design & Build
- Parts
- Digikey National...no
