Here goes,
First of all, AES /EBU and SPDIF actually use slightly different data format. But, if you are just going from a source into a DAC, that usually doesn't matter, unless the DAC has a bitrate and error-rate display.
I think what you may be asking is:
How to go from balanced 110 ohm 5 volt to unbalanced 75 ohm 0.5 volt.
The answer is to use a transformer. There are various devices about. Depending on how critical you are, you could spend lots on one from Sowter or Schott, or you could use a data pulse transformer from RS or Farnell.
As for the the level difference, I would forget about it. You'll upset more with attenuators than you'll gain with level accuracy. besides, most reciever chips accept both levels.
Now, who's got a better constuctive suggestion?
Hey John
The sources are all in the digital domain and will be kept there so I wont be goin into a DAC...
Looking at FIG1 in this Pic:
I can just use a few resistors compared to forking out for a transformer, but I'm just wondering the values of the resistors used in the diagram - is it 2 x 56ohm, 1 x 110ohm and a 220ohm? what are the values in the brackets?
Ta...
Dan
PS: Still aint done that PSU yet, that project is on hold atm... will be done tho!!
Ta...
Dan
If you use only resistors, you depend on the source using a transformer as an output device. This is likely, but not certain. The AES strongly recommends makers to use one, but a few don't.
The voltages in brackets are for alternative signal levels.
Please note my earlier post.
I'm just waiting for the "digital police" to catch up with me..
