I want a dig out (coax) upgrade to the Philips cd player CD-100 and CD-104 so as Revox B-225
Actually I want to get a I2S format. The splitting for left and right channel was already perform outsite of digital to analog converter device by the first generation cd player, i. e., there are definitly two dac devices in use.
Who knows a circuit for transforming the "old bus" (SAA-7000) signals
"STR" (Strobe) "DOL" (Data Out Left) and "DOR" (Data Out Right) to the I2S signals
"WCLK" (Word Clock resp. L/R-Clock), BCK (BCLK Bit Clock) and Data ?
If I have this, I can create a one wire SPDIF bus (Sony Philips Data Interface) respective DOBM (digital out bi phase mark) about the PCF3523P
Datasheets for SAA7000, SAA7010, SAA7020 and SAA7030 are to download about
http://tube.freeweb.hu/index.html
In this case I have found also follow informations:
http://www.diyaudio.com/forums/showthread.php?postid=659436
http://www.diyaudio.com/forums/showthread.php?t=54970&page=3
http://www.diyaudio.com/forums/showthread.php?t=85641&page=2
but unfortunately I haven't success to find weblinks about a glue logic schematic for diy.
Thank you for your advices
I have found this thread to exactly the same topic:
http://www.diyaudio.com/forums/showthread.php?p=1940385&posted=1#post1940385
but also without circuit solution - only any common advices I have read
Hallo tiefbassuebertr ,
da gibt es keine Möglichkeit außer der im Link
schon genannten , da es damals noch keinen
Dgitalausgang gab und deshalb der interne
I2s - Bus benutzt wurde .
Du könntest höchstens einen anderen Dac der
l+r braucht benutzen , aber da kommt es dann
auch wieder auf die Bittiefe an , alles so wie es in
Deinem Link zum anderen Thread schon steht .
Trotzdem viel Erfolg bei Deinem Projekt !
mit feundlichem Gruß
Jürgen
Jürgen
Because the SAA7000 and SAA7020 are inside in a wide range of first generation cd players (not only by Revox B225 and Philips CD-100, as I think at starting of this thread) please go to the follow thread:
http://www.diyaudio.com/forums/showthread.php?p=1940808&posted=1#post1940808
to the same topic there are also this threads:
http://www.diyaudio.com/forums/digital-line-level/168578-saa7210-instead-saa7010.html
http://www.diyaudio.com/forums/digital-source/58700-remove-saa7030.html
http://www.diyaudio.com/forums/digital-source/67469-spdif-output-saa7020-saa7000-7.html#post1940808
Great advice. Who have work with it and can post first experience reports?
Hello.
Sorry for my bad english.
Recently I bought à Marantz CD 54, with CDM1, I would make a drive with a CDM1.
A friend told me you can't do, because 14 bits for TDA1540. **** !
So i was looking for manuals of CD players with CDM1 and TDA1541 ( too much money to buy one)
CD-Player-DAC-Transport List
- Marantz CD 94 i have the manual and schematics.
- Wadia WT 3200 WadiaWT3200
- Mac Intosh MCD 7000.
Too much discrete components on the CD94 around the SAA7010 vs the Wadia , why ?
I bought a SAA7210 and a SAA7220 ( the last couple available in this webshop ).
Then I compared the various input and output signals between SAA7010 and SAA7210.
I couldn't find SAA70000 and SAA7010 datasheets.
The first différence is : SAA7010 extract P bits
and SAA7210 extract Q bits ; it works with Q-Channel ( more informations about tracks ).
Compact disk digital audio
It's not the same serial protocol with the processor.
So I can't use the processor and the display panel of CD54 with SAA7210
Another difference is the MOTOR SPPEED CONTROL
SAA7010 gives a 50 % duty cycle
SAA7210 gives a 20 % to 80 % duty cycle with a large start pulse.
Another diff is the CRI signal from the processor to SAA7210:
When you skip tracks CRI disable the reset of master counter when it detects a new SYNC which comes in a bad time window, to avoid disturbing the speed control of the spindle motor.
I don't want to buy a CD 94 for extracting his processor to build a CDM1 drive with the CD 54 . If I had one I would use the CD 94 as a drive.
You can build a drive with CD PRO2 LF, but it's not interesting , you just have to connect boards and it works ! A monkey could do this job !
Then you have to tweak it with a super clock ( TCXO ) with ulta low noise power supplies, a super S/PDIF coaxial output and separate power supplies for every parts .
So I have to use a new µprocessor and and to write its software from scratch , step by step.. I've some samples of CD players logigrams, from power on.. open:close, focus, disc detect, play, and so on..
I've got a Radiola CD 1006 for 10 € : I would use it for investigations with my Tektro ( especially for Qbits, skip tracks, etc.. ). It has a poor TDA1541 with SAA7220, but no SAA7010 ( because decoder is on the CDM2 board ) **** !
I 'll use a Texas Instruments Piccolo µprocessor . It's luxury : 32 bits realtime and floating point 50 MHz DSP, but I know it, I'have the development kit Contol Suite and you can get it on a mini board 100 pin DIM for 49 $, and i'll have monitoring on my PC with isolated RS232...
C2000 32 bit 28x Piccolo? Series Tools & Software from Texas Instruments
C2000™ 32-bit Real-time MCUs - 28x Piccolo™ Series - TMS320F28027 - TI.com
I'll have to tweak a bidirectional I/O for QRA signal into separate I and O in the Picolo..
So I 'll design
- a new board with SAA7210 SAA7220, SRAM super clock and SPDIF,
- a new board for motor drivers, focus coil
- a LCD touch screen panel ( with service and monitoring modes ).
And a separate box for power supplies.
So I 'll design
My articles on doing this referenced here: http://www.diyaudio.com/forums/digital-source/136648-perpetual-technologies-p-1a-2.html#post2930850really no circuit solution for this?
I never realized this approach but obviously other guys - go to:Hallo tiefbassuebertr ,
Jürgen
Ich habe das Projekt nie realisiert, aber offenbar andere wie hier zu sehen:
DJ9KW's SPDIF Interface fpr SAA7000 / SAA 7010 / SAA 7020 / SAA7030 Philips Chipsets
- Digital Source
- dig out (S/P-DIF, DOBM) for Philips CD100 and Revox B225 (only SAA7000 data out)
