Thank you Endia...... this was great...but really, Rudi has a very good one
already made,..... thank you anyway...nice cooperation...check for errors Endia, to avoid people frustrated trying and having mistakes that are very normal to happens.
I am uploading nice audio recording (video) using Dx Blame ST plus Dx Module Super A plus low pass filter (active) plus a circuit to Blend...all this into a cheap speaker... awesome result in my home.
I am feeling good... as i could do that..... this is an old dream...to make cheap speakers sound fine... because the opposite, good speaker, good room acoustics, good audio source...well...this way is easy!
regards,
Carlos
regards,
Carlos
They are filters Juan.
Please folks, observe a Dx Blame ST together a Super A module, plus an active low pass filter + blend circuit connected into a cheap speaker.
Resulted very good:
Dx Blame ST+ SuperA+Low pass+Blend+cheap speaker - YouTube
regards,
Carlos
Resulted very good:
regards,
Carlos
thanks all..
Carlos, in your psu bom, there are two sets of R7/R8 (3R3 and 33R). but first set is not shown in the schematic. should i omit the first set?
also i have 0.6 mm enamelled copper wire, may i use it instead of 1 mm? if it so how many turns should i do?
thanks..
thanks..
33 ohms is fine..... was an upgrade..... about turns
from 12 to 33 will be fine.... you decide if you want several layers or not.
Your wire will be good too...no problems..short lenght, even this smaller diameter wire will not create resistance.
This is not critical...it is there "just in case" you have noises in the rails...as usually we do not have noises in the rail...they do nothing almost all the time.
regards,
Carlos
regards,
Carlos
Hey Rudi don't worry, I can not point out errors to your work you are a professional already, I have seen your work and is really well made design and beautiful, is me I'm still learning my man, and you can point out mistake of my layout and I don't even get mad I will say "thank dear friend now I can fixed"
vargasmongo3435
vargasmongo3435
News about my DXAmp! I find a new heathsink to it!
Photos at:
Felipe Navarro: DXAmp - Novo dissipador
Photos at:
Thank you Navarro
But now we are taking care of a new and better design.
Sadly, each new model kill the last one...this is life...we drink Pepsi and we feel good..till the day we drink Coca..then we will not drink Pepsi anymore.
But Pepsi is good too.... you can have it at room temperature when we will not like the Coca Cola same way....also you can have Pepsi without gas...but you will not drink Coca Cola without gas.
Dx Blame ST, Dx amplifier (the first and standard model) and all things i have done were destroyed and smashed by the Dx Super A.
Dx Super A is a retuned Dx Blame ST that has 1 watt in Super A (Class A) operation...when you increase volume it leaves class A and becomes a standard Class AB audio amplifier alike the Dx Blame ST and several others.
Advantage is into the sonics that is from outside earth... divine..the voice of God.... distortion is very low and third harmonic is many times smaller than second harmonic..so...people use to call this "tube" sound... i do think it reminds me....but tubes would be very happy if they could produce this sound... eated tubes too..and in the breakfast.
Esse sentou encima dos anteriores e soltou um pum de desprezo e desrespeito ... essa é a forma que os macacos fazem para demonstrar domínio e superioridade
This one has sitted over the old ones and have ejected a fart showing disdain and disrespect, this is the way ape community does to show domination and superiority.
And we are no more than sophisticated (and arrogant) apes.
regards,
Carlos
regards,
Carlos
Hi all,
i have one more question about Carlos's psu.. i have this transformer which has twin secondaries and according to the datasheet, this is what i am planning to wire it to the ps board.. i'm not familiar with high voltages and double checking everything, so i need your confirmation.. thanks..
- Destroyer x Amplifier...Dx amp...my amplifier
