Ecat, thank you very much
Ecat, muchas gracias y muy buen trabajo. Una pregunta, la PCB terminada del post #3597, donde se encuentra?, podrias exponerla en formato .pdf o .jpg. Funciona a la perfección? Tengo ganas de fabricar tu diseño. Otra cosa, cual es el esquematico? Saludos y respetos.
Ecat, thank you very much and very good work. A question, the PCB finished of the post *3597, where he(she) is?, podrias to expose it in format .pdf or .jpg. Does it work to the perfection? I have desire of making your design. Another thing, which is the schematic one? Regards and respects.
Saludos desde Argentina.
Hello
Here's a nice web page for those who want to learn about amplifiers, etc.. It's well done and quite easy to read and have illustrations, some pages do have some math but most have examples and some beginer guides.
http://www.st-andrews.ac.uk/~jcgl/Scots_Guide/audio/Analog.html
Gaetan
Gaetan
Hello
And it's a prety big web site, there is more than audio, he even talk about radar, radio transmission, digital audio, etc...
You can start from there, it's the long, but interesting, alphabetical list of his electronic's subjects;
http://www.st-andrews.ac.uk/~jcgl/Scots_Guide/contents.htm
Gaetan
Gaetan
Hello Carlos & friends,
I was reading the related website and saw this:
"A large number of them exploded, some worked fine, but only about 8 amplifiers sounded really good."
Carlos -- could you list the about 8 that you liked -- I'm really curious.
Sorry if you've done this already, but this thread is really, really long (I'm up to page 37, It's like a huge book, but it's fun and very educational).
Keep up the good work! I'll will be building a DX amp in the future.
Andrew
Andrew
Yes Nogoodboyo and Nordic...that thing is terrible
I am using medicine...injections...cannot sit so many injections i have applied to myself.... Sódium Dhiphirone.... against pain only.
Dear Nordic, the output inductor is beeing used to correct some overshot i had.... from 3,3 uH and up it will start to control the overshot (i could not listen..but you know..to make the best possible).... 6uH is fine...but to "kill" the overshot...sorry to say...you will need 10uh.... this is a very big coil....not practical to use....not good.... use half milimeter or 1 milimeter wire...diameter around 10 milimeters and produce 80 turns.... around 4 layers over some air core or over resistance.
Sound is a little bit different when using coils..seems lazy...there are delays...you perceive the attack speed of audio waves delayed...but...kill the overshot.
A very good chance to listen those things dear Nordic...install the coil and them remove it.... listen once again the same music..... time between changes must be very small...brain adjust everything and you will find fine with coil and without coil.
But, if you do this fast...playing music.... wire jumper hold by your fingers.... this way you will perceive.
remember to paint the points were to place hand jumpers, over the coil, not to produce shorts in other places (as i use to do)
My soldering iron is having a good rest time those last days.... this one is Hikari, 30 watts, made in brazil with Korean licence.
regards,
Carlos
regards,
Carlos
Hi Nordic,
Something like this might help with calculating coil inductance.
http://www.lalena.com/audio/calculator/inductor/
http://www.66pacific.com/calculators/coil_calc.aspx
Cheers ......... Graham.
- Destroyer x Amplifier...Dx amp...my amplifier
