Konnichiwa,
I noticed in several cases that despite previous notes and the application notes on the S&B Website for the LCR people struggle to work out what can be done and what not. So, I'll try to cover here the principles.
Please note that said principles apply equally to the 600 Ohm RIAA Modules, the S&B 600R and 10K RIAA Modules use EXACTLY the same Circuit, merely the component values have been adjusted to give the desired impedance.
The first thing to understand is that these networks are constant impedance T-Networks. In other words, they operate in a constant impedance envoironment and themselves present a constant impedance load at their nominal impedance (600R/10K).
This means in a "classical" situation the RIAA would be terminated with it's nominal impedance on either side, in other words the source impedance of the receeding stage would be made equal to the RIAA Modules and the RIAA Module would be loaded with it's nominal impedance.
In practice one of the terminations can be omitted, but NOT both. This means you either operate the RIAA Module with a near infinite load impedance and from a source impedance equal to it's nominal impedance.
OR you load the RIAA with it's nominal impedance and then you are free to select the source impedance with impunity.
In fact, I used this feature in my E810F/D3a Phonostage with the 600R RIAA Module shown here:
Here I use a Penthode stage which hase around 8KOhm output impedance and a gain of around 50db. This stage is then loaded with the 600 Ohm RIAA which results in a loss of gain of 23db brining the gain into the RIAA down to around 27db.
The bottom line, you need either a load or source that is equal to the nominal impedance of the RIAA within a few %. In any case, the stage driving the RIAA Module will be loaded by an impedance equal to the RIAA Modules Impedance, plus the effect of the Anode load, which appears in parallel with the RIAA Module.
The easiest way to GUARANTEE that the RIAA performs accuratly with total disregard to valve aging is to load the RIAA Module with it's nominal impedance and to insert a coupling capacitor of suitable value in front of the RIAA Module. The minimum capacitor that works with a 10K RIAA Module is around 2.2uF and for the 600R RIAA it is 39uF.
The next thing is to have a first stage in the Phonostage that is able to drive the load of the RIAA Module without massive distortion and at the levels required plus it is required to stiull develop usefull gain into the load presented by the RIAA Module.
While it may be tempting to use an ECC83 as first stage, this stage would show an output impedance in the region of 50KOhm or more and would distort heavily into a 10K load.
Therefore we need a Valve with low anode impedance and reasonably high gain. Among the common small signal valves the ECC88/6DJ8/6922 will answer the purpose reasonably.
Better choices will be valves with more gain and higher transconductanace such as the WE 417A, WE 437A, russian 6S45PE, 6S4P, 6S3P or triode wired high transconductance pentodes such as the E180F/6688/6Z9P, C3g or E810F/7788 and D3a/7721. Some of these may even be used directly to drive the 600R RIAA Module.
For our example however I will stick to the 6DJ8 and the 10K RIAA as it is readily available and known. The calculation of the other examples shall be left to the genteele reader as an excercise in applied math.
Let us first understand what sort of signal comes from the cartridge. Most cartridges are rated for an output in a certain mV amount for a deflection of 5cm/s. A typhical range for Moving Magnet Cartridges is an output voltage of 2.5 - 10mV @ 5cm/s.
Conveniently so-called low-output moving coil cartrdiges have outputs usually in the region of 0.25 - 1mV @ 5cm/s, making the use of a stepup device with a 1:10 stepup (transformer) easy to get the levels to the same range as the Moving Magnet Pickups.
Now is 5cm/s the maximum level on a record? Nope, records can be cut with up to 14..16db MORE level than that, at least for a range of 100Hz - 5KHz (appx.), this is called headroom. Many well recorded and well cut LP's will have levels as high as that.
In order to accomodate all possible LP's and pickups we therefore must expect operational levels on the grid of the first stage of around 14db above 10mV or in other words 50mV. We should also expect levels CONSIDERABLY HIGHER at high frequencies caused by pop's and clicks, however these only appear with Moving Coil cartridges, with MM Cartridges the high frequencies roll off following a 2nd order function somewhere at the top of the traditional audio band, depending on capacitive loading.
So, our Grid of our first stage will be exposed to around 50mV operational signal and see transient pops and clicks at maybe 100 - 200mV. And it will drive a 10K RIAA using a valve with a nominal gain of 33 (ECC88). So the maximum operational signal applied to our RIAA Module will be around 1.5 - 2V, less in reality due to gain losses into the 10k load.
Now for low distortion it is desirable to have only 1/10 of the actual anode current varied by the signal (rule of thumb), so we need to find the peak current into 10K for say 2V peak voltage, we get 0.2mA, so our first stage shall have at the very least an anode current of 2mA plus whatever is needed to account for the current variation in the anode resistor.
My 6DJ8 Datasheets charaterise the Valve at 90V Anode Voltage, allow me to be lazy and use this point, a +B of 250V and a current of at least 4mA which gives a 27-33KOhm . My curves suggest a 33K Anode load and around 4.5mA current, which leaves us some voltage (9V) for a decoupling RC circuit, 2K2 seem apropriate.
The 6DJ8 appears to require 2.3V Bias at the above operating conditions, this then means a cathode resistor of 10 Ohm. If we leave this resistor unbypassed you get the cathode resistors value "amplified" by the Mu of the valve and added to valves anode impedance, which is nearly 5k at the operating point chosen.
So, with an unbyassed cathode R of 510R our effective anode impedance becomes around 20KOhm, way too much to be usefull with a 10K load as we would loose ton's of gain. Therefore we would need to do one of two things. We can bypass the cathode resistor with a 100uF Capacitor OR we can increase the current, to say 15mA and reduce the cathode resistor.
15mA at 90V require 1.2V Bias and thus a 82R cathode resistor. Effective anode impedance with unbypassed Cathode resistor is now around 5K but our Anode load resistor needs to drop to 10K. With that we have an effetcive load on the Valve of 5K (10K Anode load in parallel with 10K RIAA Module) and a 5K source impedance, so our gain of the first stage into the RIAA Module will now be around Mu/2 or 33/2 = 16.5 = 24db. The RIAA Module attenuates 20db @ 1KHz and thus after the RIAA we have a remaining gain of 4db.
If we now add a second stage in identical arrangement after the 10K RIAA Module and it's load resistor we will for that stage have a gain of 22 (27db) into high impedance loads and around 3K Output impedance. In total our Phonostage would have a gain of 27db + 4db = 31db, which is low but adequate (the Zanden Phonostage has a gain of 33db).
The circuit would look like this:
We could now take some measures to bump up gain.
We could use of diodes to bias the Valves (you could use a pair of standard 1N4001 in series with the commoned cathodes of both valves) This would reduce the effective Anode impedance for both stages to around 2K5 and would thus bump up the gain of the first stage to 22 (27db) and of the second stage to 26 (28db) with an overall gain of 35db.
Alternatively you could battery bias the second stage grid from a 1.2V or 1.5V battery in series with the 10K resistor and ground the cathode. And you could even use the series grid bias methode shown variously on the net like this:
The next step could be to substitute current sources like the Bottlehead C4s (www.bottlehead.com) or the CCS Kit offered by K&K Audio (www.kandkaudio.com) for the 10K Anode Load resistors. This gives us back even more gain, if no external load is present the output stage will give basically the full Valves "Mu" at 33/30db and the first stage gets up to 26/28db, giving overall 38db gain.
It shall be left to the genteele reader to apply these current sources and different bias methodes to the circuit as an excercise.
If the excercises appear too difficult a little study of the materiel provided in the On Line Tube Learning for newbies.... Thread (sticky thread at the top of tubes board) may remedy the difficulty.
Sayonara
Sayonara
Thorsten,
THANKS for the detailed explanation.
I recall seeing some "chatter" to the effect that the 600 Ohm RIAA module is superior to the 10 KOhm version. Is the "chatter" correct?
I've been mulling over a 6DS4 loaded by a Gary Pimm CCS as the 1st gain block of a phono stage for some time. The impedance of the CCS' mu follower O/P is a few hundred Ohms. Am I correct in thinking that the 600 Ohm RIAA module will be fine driven by the CCS' mu follower O/P, so long as the grid leak resistor of the 2nd gain block is 604 Ohms?
If my thinking is reasonable, could you make a recommendation for the coupling cap. that goes between the CCS' O/P and the RIAA network?
TIA for a response.
Eli D.
TIA for a response.
Eli D.
Konnichiwa,
I have not had a chance to compare, the 10K RIAA's are in sort supply and I have come up short again and again (well, lack of time let me tell JB "okay, send them off elsewhere")...
Assuming the Mu-Follower operates at sufficient current to sustain the neccesary output voltage into 600 Ohm - Yes.
You will need a VERY large value capacitor. If you accept -3db @ 20Hz (which I do not) you need around 12 - 15uF, for a -3db point of 4Hz (which I aim for) you need 68uF.
You COULD use another trick.
The Mu-Follower output of your circuit has a low and fairly well defined impedance. The S&B Riaa contain Capacitors with 630V or more DC rating in all shunt path, so it will withstand quite a bit of DC offset, as long as no DC current flows.
Therefore, if your source can be made to have 600 Ohm net impedance you can couple the S&B RIAA (and ONLY the S&B one) directly and place the coupling cap AFTER the 600R RIAA, making it's value uncritical.
Sayonara
Eli Duttman said:I recall seeing some "chatter" to the effect that the 600 Ohm RIAA module is superior to the 10 KOhm version. Is the "chatter" correct?
Eli Duttman said:I've been mulling over a 6DS4 loaded by a Gary Pimm CCS as the 1st gain block of a phono stage for some time. The impedance of the CCS' mu follower O/P is a few hundred Ohms. Am I correct in thinking that the 600 Ohm RIAA module will be fine driven by the CCS' mu follower O/P, so long as the grid leak resistor of the 2nd gain block is 604 Ohms?
Eli Duttman said:If my thinking is reasonable, could you make a recommendation for the coupling cap. that goes between the CCS' O/P and the RIAA network?
Sayonara
May I ask what kind of musical information you're hoping to find on a record at 4 to 20 Hz?
Information that, if at all present, will be filtered out by the RIAA correction anyway.
To the best of my knowledge the only thing to be found in that frequency range are subsonic resonances stemming from cartridge/tonearm interaction.
Amplifying those will only give you a false sense of bass response much the same way speaker cabinet resonances appear to be part of the music to some (most actually) people...........
EDIT: There should be no reason whatsoever for a 600 Ohm LCR
RIAA filter to be "better" than a 10K one provided both are properly designed and implemented.
I'm mostly with Frank
Trying to get too much low frequency response from a RIAA preamp is asking for trouble.
The RIAA Spec is:
75us low pass (2122Hz)
318us high pass (500Hz)
3180us low pass (50Hz)
This spec. was later modified by IEC to add a 10ms High Pass (16Hz).
The problem with the straight RIAA spec. is turntable rumble at approx 0.5Hz (33 r.p.m.) together with the 3180us (50Hz) low pass. This means response is increasing (at 20 dB/decade) below 50Hz. The response at 0.5Hz can therefore be +40dB above the 50Hz response. Even if your power amp /speaker etc can't reproduce the low frequencies you run the risk of saturating the preamp active stage(s).
IEC added the extra pole at 16Hz to make sure response was well down at turntable rumble frequencies.
My own experience was that I couldn't tell any difference with this extra pole anywhere between the recommended 16 Hz and an experimental version built with this extra pole at 32 Hz instead of 16Hz - I left it at 32Hz.
Of course this experience was with a solid state phono preamp with a mix of active and passive compensation and the LCR MAY not exibit this problem.
It is something to be extremely wary of when designing phono stages.
Ian
The RIAA Spec is:
Ian
This is where current hogging by unmatched tubes sharing a common cathode resistor in a push-pull output stage can get real ugly.
John
Re: I'm mostly with Frank
If I recall the RIAA curve was ammended to deal with the arm mass/cartridge compliance resonance, rumble from mechanical sources such as vinyl surface and bearing noise, and reduce susceptibility to footfalls and structural and airborne feedback. Disc eccentricity is far below the high pass created by most cartidge/arm combinations and doesn't manifest itself as a .5 Hz signal of any significance but as a cyclic speed variation. The RIAA curve won't help fix this but it is effective on the rest.
gingertube said:The problem with the straight RIAA spec. is turntable rumble at approx 0.5Hz (33 r.p.m.)
Konnichiwa,
You may ask.
You may also ask yourself what result multiple 3db rolloffs at 20Hz daisychained have further up in the audio band.
!!?? I fail to see ANY logic in this statement.
The RIAA EQ causes a boost of 20db @ 20Hz compared to 1KHz and should show a flat response below 20Hz (unless you subscrive to the ill advised IEC Ammendment to the RIAA curve).
How would that lead to the low frequency information on the LP being filtered out?
Then, with all due respect, the best of your knowledge could use some improvement.
Sayonara
fdegrove said:May I ask what kind of musical information you're hoping to find on a record at 4 to 20 Hz?
You may ask.
fdegrove said:Information that, if at all present, will be filtered out by the RIAA correction anyway.
fdegrove said:To the best of my knowledge the only thing to be found in that frequency range are subsonic resonances stemming from cartridge/tonearm interaction.
Sayonara
Konnichiwa,
Why exatcly is that?
An ammendment most ill advised for use with quality equipment though clearly advisable when used with poor quality turntables (eg the $ 50 all plastic jobs with loads of resonances and ruble)/
Hmmm. It is trivial as engineering problem to make a turntable essentially free from rumble (though not neccesarily cheap). Therefore, there is no problem with quality equipment.
One would, perhaps wrongly assume that someone tinkering on a phonostage with $US 480 worth of LCR RIAA Modules would combine said phonostage with a quality turntable.
YOU WHAT? Please retake EE101.
A 50Hz lowpass implies that anything below 50Hz passes (therefore LOW-PASS) while ABOVE 50Hz the response rolls off 20db/10ade or 6db/8ave.
No it cannot. it cannot be any higher than the 50Hz UNLESS you have arm cartridge resonance at around 0.5Hz.
HOWEVER, most arm/cartridge resonances are around 8-16Hz (for good reasons too) and therefore any output below the Arm/Cartridge resonance rolls off steeply, at least 40db/10ade..
Chemically pure horse excerement. Please get your facts right.
They did, but primarily because cheap turntables had very high levels of rumble, not for the reasons you invented..
NO, IT IS ABSOLUTELY NOT.
You may be weary of getting your arm/cartridge set up wrongly.
Adding an LF rolloff higher up in the audio band (even at the IEC recommended 16Hz) has a clearly audible impact if you system has sufficient bandwidth and is often audible even when not. Steeper slope filters (such as advocated by D. Self) are especially problematic.
Sayonara
Konnichiwa,
gingertube said:Trying to get too much low frequency response from a RIAA preamp is asking for trouble.
gingertube said:This spec. was later modified by IEC to add a 10ms High Pass (16Hz).
gingertube said:together with the 3180us (50Hz) low pass. This means response is increasing (at 20 dB/decade) below 50Hz.
gingertube said:The response at 0.5Hz can therefore be +40dB above the 50Hz response.
gingertube said:Even if your power amp /speaker etc can't reproduce the low frequencies you run the risk of saturating the preamp active stage(s).
gingertube said:IEC added the extra pole at 16Hz to make sure response was well down at turntable rumble frequencies.
gingertube said:It is something to be extremely wary of when designing phono stages.
Sayonara
Re: Re: I'm mostly with Frank
Konnichiwa,
You are absolutely correct. However, correctly set up arm/cartridge combo's have little effect in the audible range and a quality turntable setup should be substantially free from rumble, susceptibility to footfall and the like. Well cleaned records show little noise.
Therefore the IEC ammendments is suitable to low quality equipment but should be avoided in high quality equipment.
If we assume (for arguments sake) 4 daisychained open loop Valve stages (which is the case for my own system) with all dominant timeconstants set to 40mS/4Hz we find that with four times this we will attenuate 4Hz by a total of 12db (3db @ 4Hz X 4 with a 4th order slopw below 4Hz.
Each 4Hz pole will also attenuate 20Hz by 0.17db, therefore with four poles at 4Hz daisychained we find that 20Hz is attenuated 0.68db already. It would seem undesirable to add more unneccesary rolloff, at least for quality equipment.
Sayonara
Konnichiwa,
rdf said:If I recall the RIAA curve was ammended to deal with the arm mass/cartridge compliance resonance, rumble from mechanical sources such as vinyl surface and bearing noise, and reduce susceptibility to footfalls and structural and airborne feedback. Disc eccentricity is far below the high pass created by most cartidge/arm combinations and doesn't manifest itself as a .5 Hz signal of any significance but as a cyclic speed variation. The RIAA curve won't help fix this but it is effective on the rest.
Sayonara
Those roll-offs are still there whether the corner frequency is lowered or not.
"Should be filtered" would be have been a better way to put it.
Let's just say I tried that path even down to DC as far as the coupling between the first two stages goes.
It taught me exactly what I suspected all along, too much LF garbage for comfort.
Not to mention the fact that the results were downright disastrous even to the point of being dangerous to the reet of the system..........
YMMV but I doubt it......
In short it's just plain disaster, something a little common sense or "knowledge" about TT systems can tell you straight away.
Konnichiwa,
But what they do higher up is reduced if they are lowered below 20Hz, which is what i propose.
Sorry, but it is not so that they "should be filtered".
You should perhaps concentrate on your turntable setup first.
With a wide range of actual turntables which I have owned over time or had in the system (a number of eastern block belt drive tables, various Japanese "battelship" Direct Drive ones from Sansui, Kenwood and Technics, Systemdek IIX, Oracle Delphi and now the Acoustic Solid) plus a variety of tables with friends (VPI TNT, Linn LP-12, Garrad 301/401 and various EMT's come readily to mind) there is no problem with "LF garbage" using phonostages with extended LF cutoff.
I am not sure how you managed to attain such results, but it points to an extremely poor turntable or very poor setup of a good one.
Pretty much ANYONES milage will vary, assuming they use a competently set up "quality" turntable.
Actually, common knowledge and personal experience with many turntables tells me nothing of the like, as long as quality equipment is concerend.
Sayonara
fdegrove said:Those roll-offs are still there whether the corner frequency is lowered or not.
fdegrove said:"Should be filtered" would be have been a better way to put it.
fdegrove said:Let's just say I tried that path even down to DC as far as the coupling between the first two stages goes.
fdegrove said:Not to mention the fact that the results were downright disastrous even to the point of being dangerous to the reet of the system..........
fdegrove said:YMMV but I doubt it......
fdegrove said:In short it's just plain disaster, something a little common sense or "knowledge" about TT systems can tell you straight away.
Sayonara
Os2 Warp Mode On....
O.K....
So you go tell the good folk over at Nothingham Analogue their 120 lbs spinner stinks, tell the guys at Air Tangent they don't have a clue what a tonearm should be designed like and last but not least you can have the pleasure to tell mister Jan Allaerts his masterpiece MCs stink as well.
All among the greatest of the planet and sure enough I stink at setting this stuff up regardless of the fact that I actually have designed just about anything bar cartridges in that department....
I can't even imagine the number of analogue systems I've set up...
No Sir, the problem is not the gear, not the rumble but just plain interaction of the vinyl, stylustip and tonearm that will give a very strong resonance at around 10 to 16 Hz and it won't just stop at those frequencies either.
No amount of setting up will get rid of that.
So yes, this tremendous energy that has no relation to the music should be kept out of the system as early as possible.
Besides, you never answered the question: what musical content is there to be found below say, 16Hz on a vinyl record anyway?
None?
Hmmmm.....Guess they left it out for a reason too, right?
Not to mention record eccentricities, warps etc....
Just put on a disc with a blank surface and crank up the volume, you'll know what you'll be amplifying when you let too much LF garbage through.....and that's on what most people would consider a decent system anyway.
Should no such record be available, just hook up a scope and watch your local tsunami at work....No, it's not supposed to be funny, I know....
O.K....
None?
Hmmm, the debate about EQ is interesting. I'll add my 2 cents.
I agree with Thorsten that keeping the original curve is best. AMOF, keeping the original curve is best even with inferior equip., as the IEC mod. simply does not get the job done. As always, keeping the baby while disposing of the bathwater is desireable. Disposing of infrasonic garbage (when present) while minimally impacting the audible band is the object. A 3 pole filter 3 dB. down at approx. 17 Hz. disposes of the trash. The "Catch 22" of the filter is phase distortion introduced into the audible band. Butterworth filters are poor performers in the phase shift department. At the end of the 1970s and into the early '80s, I used a Sansui 7070 receiver and BIC TT. The presence of infrasonic trash was manifested by the fluttering of the woofer cones. I acquired an audio bandpass unit that used Bessel function filters, which are purported to be good performers in the phasing department. The benefits were clear. Cone flutter was abolished and the overall sound improved. Infrasonic trash in addition to wasting power also causes IM distortion in the audible band. Obviously, superior equip. that doesn't produce the garbage to begin with is better.
Shifting gears, I EMailed Gary Pimm a link to this thread in the hope that he will comment. Thorsten's remark about setting the O/P impedance of the 1st gain block to 600 Ohms looks VERY interesting.
Re: OS2 WARP MODE ON....
Konnichiwa,
Maybe. Of the above I only know the NA Turntable. It is rather good. As for the rest, there is such thing as setup error and/or mismatch.
In a very poorely damped arm/cartridge combo such as evident with a sure V15 your VLF peak will be in the region of 10db (measured), using a pink noise track on LP and 1/6 octave weighting I found in my own turntable only one combo of cartridge and arm with more 3db boost overall and notable boost at 20Hz, that combo being an Ortofon SPU and RS-212 Arm. My other two combos (Denon DL-103/SME 3009 & Origin Live Silver 250/Goldring Elite) show less of an issue (that is across the Phonostage and Arm Cartridge, the Phonostage itself haveing very extended LF response)..
The issue is not per se musical content and more crucially, it is not what happens at 16Hz, but what your filter causes to happen higher up in the spectrum which leads (IMHO) to the audible problems.
In temrs of perception, taking out significant parts of the very low spectrum reduces in many recordings the "thereness" and/or acoustic sense of the actual recording space. What particular parts of what is recorded is of modest concern to me.
Record excentricities are at around 0.5Hz and will be already suppressed by around 40db if you use a Setup with an arm/cartridge resonance in the 8-16Hz region. Plus at 0.5Hz our 4Hz turnover will have added nearly another 20db of attenuation.
I know very well what this is.
First, please use a record NOT with a blank surface but with a grove cut without modulation (any good test LP will have such sections). Inter Track unmodulated grooves may also be used sufficiently.
And at volumes that are near max with signal you can indeed see some cone flapping if the record is either very excentric or very warped. Using records that have no obvious problems leads to very little observable problems with VLF signals.
So, the bottom line is that while you may observe some issues, in practice and with quuality equipment they fail to be overly observable.
Sayonara
Konnichiwa,
fdegrove said:O.K....
fdegrove said:No Sir, the problem is not the gear, not the rumble but just plain interaction of the vinyl, stylustip and tonearm that will give a very strong resonance at around 10 to 16 Hz and it won't just stop at those frequencies either.
fdegrove said:Besides, you never answered the question: what musical content is there to be found below say, 16Hz on a vinyl record anyway?
fdegrove said:Not to mention record eccentricities, warps etc....
fdegrove said:Just put on a disc with a blank surface and crank up the volume, you'll know what you'll be amplifying when you let too much LF garbage trough.....
Sayonara
Sure....
I like my system to be as wideband as possible too for the same reasons but....
It seems to me someone has forgotten that when it comes to vinyl there's only there what's actually been put on the recording in the first place.
If you're talking about extending the LF response of a phono preamp by stretching the RIAA standards for playback maybe you should also consider that the inverse curve of that RIAA standard was used to cut the record in the first place....
Should extending the LF passband to as low as 4Hz not wreck havoc on your system then I can only surmise that somewhere along the line it must have been filtered out anyway.
In the meantime, all that has occurred is needless modulation of PS drawing energy that could have been left for what really matters, real music, not warps and resonances.
So that's another two cents worth of "knowledge",
Sure....
Konnichiwa,
Exactly.
Yes, indeed. There is some rolloff in the cutting Amplifiers and low LF is blended mono, however usually the filters employed for cutting where not excessively steep and did not hack out anything below 20Hz untill quite late in the game (and even then they where often enough not applied). I see little benefit downgrading the reporduction to the lowest common denominator.
Correct. It is filtered out by the arm/cartridge resonance. I see little benefit from adding further to this to this fairly steep rolloff. The boost received at subsonic frequencies will partially offset attenuation during cutting, which can be seen when a well cut test LP with a pink noise track is replayed and analysed.
Really. How interesting. All my powersupplies are loaded by class a stages, so I doubt they'll notice.
Your "knowledge" seems curiously skewed. I do not dispute that what you describe is real to a certain degree. However the emphasis is on "to a certain degree". In relaity I find non of the problems you describe to be significant enough to warrant consideration, on the other hand using an excessively small value coupling capacitor (or worse a multipole filter) to roll off the "unwanted" LF content is very notable, to my ears at least.
Sayonara
fdegrove said:It seems to me someone has forgotten that when it comes to vinyl there's only there what's actually been put on the recording in the first place.
Exactly.
fdegrove said:If you're talking about extending the LF response of a phono preamp by stretching the RIAA standards for playback maybe you should also consider that the inverse curve of that RIAA standard was used to cut the record in the first place....
fdegrove said:Should extending the LF passband to as low as 4Hz not wreck havoc on your system then I can only surmise that somewhere along the line it must have been filtered out anyway.
fdegrove said:In the meantime, all that has occurred is needless modulation of PS drawing energy that could have been left for what really matters, real music, not warps and resonances.
fdegrove said:So that's another two cents worth of "knowledge",
Sayonara
Is my face RED
As KYW so kindly pointed out (YOU WHAT? Please retake EE101)this is pasture decore.
Response is flat below 50Hz and decreases at 6dB/Octave above 50Hz.
Sorry - brain was in idle.
Ian
Ian
This is a nice simple way of dealing with the coupling issue that I hadn't thought of.
With the standing current high enough to handle driving the 600 ohm module the output impedance is going to be too low to use the MU output directly. The way it could work is to include a series terminating resistor between the MU output and the input of the S&B module. The value of the resistor would be selected to make the total impedance of the MU output + resistor = 600 ohms.
There are 2 ways to get the standing current of the stage up to the level needed to drive the 600 ohm input cleanly. One is to run the triode with the total current desired. The other is to add a resistor (or CCS) to ground from the MU output. The second variation gives the ability to choose the triode current independantly of the total stage current.
Another feature of using the CCS as a load is you will get full mu of the triode without having to bypass the cathode resistor. One less cap in the circuit is always a good thing in my book.
This coupling scheme could work nicely if you are not adverse to the series terminating resistor.
Gary
Gary,
Thanks for the feedback.
The 6DS4 nuvistor is a low current type. So, a secondary current sink is the route to follow. The 6DS4 runs at a voltage somewhat less than that used for the 6922. Finding a suitable N channel FET for the secondary sink shouldn't be too difficult.
Michael Percy carries 1 KOhm Vishay 1280G trim pots. With their bulk metal foil construction, the Vishay parts seem to be the right choice for dialing the 600 Ohm impedance in. An adverse sonic impact should not be observed.
FWIW, I'm thinking of using the same red LED for bias that is used in the Bottlehead Seduction.
- Tubes / Valves
- Designing a Phonostage with the S&B 10K LCR RIAA Module
