A kind of Hysteresis Synchronous Motor was used in tape recorders (Reel to Reel and the early table top cassette machines) and possible in record players, before the on set of the Direct Drive TT's. Not much torque on start up, but pretty hefty while running. In the pictures is one such Akai 14W motor, obs. the smooth rotor.
In connection to the subject ,some links:
Welcome to Schulze
Welcome to Schulze
Welcome to Schulze
Welcome to Schulze
Nanook,you are right,pulling the paltter needs less torque,I have tested this on this TT.
I replaced the original motor by a small stepper motor,the vibration noise disappeared in stead of stepper self-noise,even I put the stepper into a cast aluminium box.This noise just like the printer head moving noise.New problem cameIt seems that I have to select other type motor,maybe a synchronous motor in photocopy.
I made a new belt by PU wire(can be heat melted & jointed),this new belt can keep in same position on platter while running.
Some new pics
Move the motor out of base
Machined half groove to keep new belt
New belt is running steady
PU wire
Some new pics
PU wire
which stepper? How to implement
The 7.5° motors I have are Thomson/Airpax P/N M82101-P1, 5VDC, 20Ω/coil. These are a 6 wire stepper and came from a photocopier or scanner.
Remember 6 wire steppers need to be fed both a sine wave (channel A) and a cosine wave (channel B) with the appropriate motor voltage to work (too high and you burn the coils). So 4 wires must be connected to a 2 channel amp. The other pair of wires must be connected together (channel A common and channel B common) for a 6 wire stepper.
I guess you could use a PIC or even a DSP to create the sine and cosine waves. You could also feed the motor a square wave, using PWM (I think).
and speed accuracy...and a fool proof motor controller
To clarify: the old Alexandria uses a Pabst "flat" or "pancake" style motor driven with a DC power supply. I have a re-plinthed Sugden BD-1 "kit" tt running straight from a wall plug. It has been verified to run at 33.33 using an AC outlet. Previously it ran too slow so I used some stretchable artist's tape to build up the pulley and drive it with a nylon thread at fairly high tension. It worked, but started to unwind , thus I tried several wraps of Teflon tape (for thread sealing pipe), and it has continued on for years.
For compete idiots like me, using a DSP might be the the simplest (or one of the simplest) methods possible to generate a good signal. Looking at the mini-dsp (as on diyaudio), even I could manage to get get this thing running reasonable well. If you use 60Hz (or 50Hz) pulley and platter then you can generate the correct frequency to run the motor at the correct speed of 300 RPM (or 250 RPM). Then get yourself some kind of amplifier (maybe a T-amp?) and a pair of small wattage step-up transformers to get the required voltage.
Another option might be the use of a 2 channel PWM controller from an RC car. The motors from RC vehicles don't spin slow enough, but the controllers are very good and can be inexpensive.
. The closest I get to a 33 1/3 RPM reading on my Oracle is to within .01 RPM (33.34 RPM, which I can live with), so accuracy is +/-.005 RPM or about .015%. Try measuring that accuracy with anything else except a frequency counter and a test record. I'd also suggest testing the speed while playing a record if using a laser tach.
EB: I see you have other tts...
...have you modified them too? What are they?
Glad you have found the source of the noise issues and changed the motor. I would still seriously consider rebuilding the original motor (most likely just dirty from dust even in an original sealed box). Then buy or fabricate some motor grommets. I might still suggest a very heavy top plate made from non-magnetic stainless (some stainless is magnetic, so if buying SS then best to get non-magnetic type) or good old steel plating.
I imagine that if speed stability is good right now you have listened to the combination. How much can you say about the level of enjoyment you experience?
Nanook,I have another 2 DD TTs,LUXMAN PD370 and MRANTZ 6170,I did not modify them because they can spin steadily.LUXMAN PD370 is with VDS system,but this function is invalid because the disk seal rube has aged,but its sound is good with original heavy platter.
Yes!I also think heavy top plate can damp more vibration,I will try it.Maybe stone plate is another choice.
I played different condition vinyls including some with scratch, luckily,the cartridge can move form beginning to end smoothly on every records.The sound is good as using PD370,maybe better? You know,as a DIY lover,we normally enjoyed the whole DIY process more than the result,is it right?
A short piece playing video of “Tea For Two”,the audio is lack of bass because I record the video by DC
http://www.flickr.com/photos/45199188@N03/7627131070/
I recorded a piece of music named “Blue Tango” by this combination and converted it to mp3 format,here is this music flash playing address:
http://player.56.com/deux26_117522164.swf
Speed sensors...
EB, that looks like almost any other optical sensor out there, as used on many turntables for example: the Dual CS5000 uses something similar to control the auto functions, the sensor is mounted to the tonearm base circuit board, and a piece of thick mylar is used to block the signal allowing the motor control energize the motor. There are others that are used for a speed feedback to a motor or motor controller. I see no reason why it couldn't work. You may be able to get a similar sensor that is a direct laser/light and receiver that point away from the sensor itself---a "point and shoot" device that would allow you to shoot the laser/light onto a surface and receive the reflected light. I guess this is a laser tachometer...
I must say that I am not an electronics engineer, and thus maybe I'm dreaming...but I can't believe that this is not "do-able". I will say that if you are planning to use a control such as this on the ROK turntable, you would be better of using a good motor and typical shifting capacitor. It will be much easier to actually do and maintains the basis that is the ROK. BTW: I'd love to get my hands on one of these great old turntables.
THe VDS system is something that I would like to experience myself. If the rubber seal is deteriorated, can a new one be purchased or made? I think Luxman turntables have been forgotten.
- Analogue Source
- Design a suspended TT with REKOKUT KIT
