Two tube amps. . .
Decware Model TORII MK II
Factory Direct $2,495
Pentode 24.6 wpc (2) EL34 or 6550 or KT88 PER CHANNEL
Auto bias (matched tubes)
Tube Rectification
Point-to-point wired
36.8 lbs
Made in the U.S.A (East Peoria, IL)
30 Day in home trial
Life time warranty
VS
Rogue Audio Stereo 90 Amplifier
MSRP $2,495
triode 60 wpc (2) KT88/6550 PER CHANNEL
ultralinear 90 wpc
manual bias (unmatched tubes)
Solid State Rectification
2 ounce copper printed circuit board
60 lbs
Made in the U.S.A (Brodheadsville, PA)
3 year limited warranty
Tube Rectification
36.8 lbs
Life time warranty
VS
MSRP $2,495
ultralinear 90 wpc
60 lbs
You seem to have inside information on the design, please elaborate on what makes it so 'unbetterable'.good luck trying to find a design that would better the Rogue. Unless you know of some....
Simon
