Decoupling for OPA627, LT115 and AD8610
eplpwr said:
Hi Mads!
No, I'm not referring to OS-CON:s, although I know
they're also dry elyts. The type I've got is made
by BC components, and are sort of "drop formed",
like tantalums normally are. I'll try to attach
an image, hopefully it works...
1st page:
http://www.diyaudio.com/forums/showthread.php?postid=188715#post188715
you're getting really bad advice, the pic looks like a classic sintered Ta/MnO2 cap - the very one that is a safety hazard because it can flame out under V stress/dielectric failure
the Ta cap recommendation in most op amp data sheets is totally archaic and should be dropped, Fred's recommendation of polymer electrolyte Al electros is probably good for Ta replacement apps
but there is good info on what really happens in bypass applications and random paralleling of different caps can result in impedance peaks in the supply impedance
http://www.ultracad.com/articles/esrbcap.pdf shows the "anti-resonance" impedance peak you can get with the wrong choice of caps in parallel
http://www.pa.msu.edu/hep/d0/ftp/ru...nformation/xilinx_xapp623_decoupling_caps.pdf
also shows measured ps impedance peaking
this makes the large Al electro deliberately selected for higher esr actually a better choice sometimes
