Save yourself a toroid.
just as an exercise ...
drivers in series don't 'sync' like parallel
(per WT3 anyways)
http://www.daytonaudio.com/index.php/test-measurement/dats-dayton-audio-test-system.html
By ear too. But the xfr is the question, not the reasoning behind it ?
will your SS amp sound like a tube amp now ? ...
hmm ... I think its the other way round
but special air core toriods are good for big inductors in speaker crossovers
Toroid pwr xfmrs do a good job with audio
as opposed to EI .
No. I'm talking 'power' xfmrs used as audio xfmrs,
ahh, got it now, thanks
but then you only want to use the thick secondary, or ?
Would you specify a transformer ?
What total power level were you thinking about?
With this information I could suggest a size but have no experience with suitability.
12Vct 1A
The center tapped secondary as autoformer works !
8 Ohm up to 32 Ohm.
BUT
Qts went from ~1 to ~0.3
(Wt-3 may misread through the xfmr though?)
- Design & Build
- Parts
- Dear Steve Eddy .......... :)
