With the handheld scope, black probe on source leg, red on gate leg, vertical amp set to 5v. Timebase set to whatever it takes to clearly display a few cycles. is the signal still weak?
Do you have 12v on the VCC terminal of the 21844s? Black meter probe on anything connected to the negative rail.
- General Interest
- Car Audio
- DD Z2 bursts output transistors
