DC Servo MOSFET Amplifier
That's not what I see.
The diode between Out and circuit becomes reverse biased when the OUT goes high.
The resistor supplies current to the LED. The LED is ON.
If Out is near GND voltage the diode does nothing, it might be reverse biased, or slightly forward biased. No effect on LED operation.
If OUT is heavily negative, the diode is forward biased and pulls the circuit negative.
Now no current flows through the LED, instead the current flows through the OUT diode.
The Diode turns the LED OFF, when OUT goes -ve.
FX100 PSU
FX100 POWER SUPPLY WITH MICRON AMP
