Fritzell said:.........the 47uF cap will prevent this.
For how long before the MOSFET switches reconnect the supply to 'speakers?
A few seconds.
It can be rebuilt with a triac or a thyristor to keep the protection on until a reset is activated. However I leave this to the individual designer. I'm happy with this circuit. Also, "connect PSU to speaker", this is only for a very very short time until mosfets brakes again. This is not worse than a high power output signal like a square wave signal.
Fritzell said:Aha. I thought mikeks ment that the circuit sucked hehe.. sorry for my bad english
Ah anyway. Yes, i agree then.
AAHHH SO!
You now realise that, once invoked, this circuit will re-connect the DC to your 'speakers-possibly destroying them?
If the reason the DC detect triggered was a shorted output device then re-closing the rail protection devices will apply full rail voltage to the speaker terminal.
Worse, the smoothing caps have had time to recharge during each off cycle.
this could be a lot worse than a square wave signal.This is not worse than a high power output signal like a square wave signal
Hi Mikeks,
thanks for the clarification.
Now re-read what you posted
what excreta are you referring to? There's the ambiguity.Purveyors of such excreta should be lined up against a wall and shot!
Hi anatech!
I think most crowbar output circuits will have a fuse rated much higher than normal output, fuse value just below crowbar capability. In some cases not, I have seen it many times.
I don't disagree, a fuse is not good. But I am interested how bad by measurement.
Hi 4fun,
I'd rather see the fuses in the supply rails. The crowbar will cause those to blow. There is no reason the voltage amp section couldn't be taken off before this so there is no danger in the output going to the other rail if only one fuse blows (unlikely). Even if it tried, the crowbar short is still applied, so the other fuse blows as well.
Works for me. Mike, you like?
-Chris
-Chris
- DC-Protect Circuitry
